Secrets of Friedrich Lüling
Started by Semi, January 19, 2022, 06:19:02 PM
truesearch
@Ufopolitics:
QuoteAnd it will be a "self runner"...
Now you have us waiting on the edge of our proverbial seats. . .  8)
I respect your years of effort on this rabbit trail of free energy. And looking forward to what you have to share!
truesearch
Semi
Quote from: Ufopolitics on October 18, 2022, 11:21:13 AM
Hello,
In my view, both videos are just a lot of talk...and no action.
Like we say in English-American..."no meat here"
We can never obtain Mechanical Magnetic Forces Neutralization by having magnets set only on one side of the model.
@Truesearch: Thks for your google translation, is enough to understand it.
And I agree with Member: magnetneutralisierung, as it is basically all about reaching a Mechanical Neutralization point with magnets, then turning OFF Neutralization at the right angles, allowing for the release of forces on the other side, whether attraction or repulsion...I mean, the principle is very basic to understand.
I am working now on a completely new model, based on same principle, except, I am turning On-Off Neutralization at the rotor, NOT at stator like I did before.
And it will be a "self runner"... ;)
I ordered some magnets and working on the required plexiglass sheets.
Ufopolitics
Hey Ufo,
good to hear from you.
Yeah, there was nothing new, neither from both of it. The one with no meat and the other is basically just pointing out that he gets it, that he truly gets it and
others don't. Also, he begins with how great he is, patting himself on the back and smearing some honey around your mouth regarding your work on the 4K footage.
He also implies, that something spoken out in front of a camera is the truth, and nothing but the truth.
It wasn't really worth to translate it...
So you've abandoned already your RMF Project? How is that?
Cheers
Semi
Ufopolitics
Quote from: Semi on October 19, 2022, 07:30:12 AM
Hey Ufo,
Hey Semi,
Thanks, same here, good to hear from you.
Cheers
Semi
Never, I always exhaust all possibilities before I abandon any project!!...and then, I may even "revive it" after a long while, just because I had a new idea.
Like has happened to my Lüling Project and his Principle, which are very special for me (I guess for you too)...that I had been working on for very long, as dedicated thousands of hours.
So, I came with this new idea now about it...just rethinking how a typical combustion engine works...basically that on the main rotor is where all pistons are attached through a Crankshaft...setting a timming to ignite, then propulse rotor.
It requires a lot more machining plus precision in the making, than a single moving stator magnet...but I believe it will be worth it.
So, I am getting all materials first to build it, while working on the CAD, first 2D...then 3D Animated.
The RMF project is on "standby" for the moment as I am also getting some materials and equipment to work on it...
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Habe die Ehre
Primitive sinnlose Kommentare führen, NICHT, zu der Lösung des Problems.
FAKTEN, KLARE KOMPETENTE, selbst erforschte Resultate,
Kenntnisse über die maximale Sättigung Möglichkeit, der Rotor Platten aus Fe 99,9 %.
NACH der Abstoßung, die Möglichkeit einer maximalen Entmagnetisierung der Rotor Platten.
DAS ist DAS FLEISCH, aus dem der Lüling Motor besteht und FUNKTIONIERT.
. Weicheisen, Fe 99,9 %, Magnetisieren, Abstoßen, Entmagnetisieren..... ∞
Mit freundlichen Grüßen
Post Skriptum. Die Neutralisierung der Rotor Platten geschieht leider im 5 bis 6 Uhr Bereich, DAS hat Lüling NICHT filmen lassen. :)
truesearch
And if what that above is in "automatic" English:
Have the honor
Primitive meaningless comments do NOT lead to solving the problem.
FACTS, CLEAR COMPETENT, self-researched results,
Knowledge of the maximum saturation possibility of the rotor plates of Fe 99.9%.
AFTER the repulsion, the possibility of maximum demagnetization of the rotor plates.
THIS is THE FLESH that the Lüling Motor is made of and WORKS.
. Soft iron, Fe 99.9%, magnetizing, repelling, demagnetizing..... ∞
Kind regards
magnet neutralization
Postscript. Unfortunately, the neutralization of the rotor plates happens in the 5 to 6 o'clock area, Lüling DID NOT have that filmed.
