kolbacict
Quote from: Ufopolitics on December 30, 2022, 01:36:34 PM
So, yes, Lenz gets behind...just because this moving field is faster than its mass-time reaction.
Ufopolitics
Right. And we can increase the speed of rotation of the magnetic field with a magnetic gearbox for mechanical gears.
A gearbox that has nothing to do with Lenz's law.
listener192
At the start your output power is a lot less than your input power.
You believe lenz is being circumvented because of the speed up condition where output voltage and current drops?
The output power decreases?
Ufopolitics
Hello,
First, I  am not trying to prove Overunity on any of these videos.
THE MAIN POINT HERE, is to understand how these systems works.
When I accelerate Field rotation, Input Amperage REDUCE, while Output Amperage INCREASE.
Input Voltage stays exactly the same.
And that is the main reason to observe here.
And I was having an issue with brush contacts, that is why I can not rise speed above a certain limit...because the brushes start separating from commutator...or not making a solid contact.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
An Amps "anomaly" captured on video...here is the image.
And of course, the Output Voltage reduces whenever I obtain these amps readings, you can tell by seen the bulb light dimmer, compared to a higher voltage on  previous video.
Note on the image the Input Volts + Amps on the blue screen...versus the AC Clamp Amperage.
I got images where the amps increased up to 6.0 amps...however, voltage dropped to the point bulb went off.
Ufopolitics
―Leonardo da Vinci
Ufopolitics
Quote from: listener192 on December 30, 2022, 02:19:18 PM
But of course, and that was the point, to demonstrate that by increasing Field Speed, Output Amperage starts to increase, while Input Amperage reduces.
For a good observer, will realize the Bulb light never dimmed out during the readings...meaning voltage kept the same levels.
Did you see output power (basically amperage) dropping?...or was it a typo and you meant "Input" instead of output?
;D
―Leonardo da Vinci
