Sergh
From old ideas:
Hysteresis motor.
https://circuitglobe.com/hysteresis-motor.html
https://engineering--solutions-ru.translate.goog/motorcontrol/hysteresis/?_x_tr_sl=ru&_x_tr_tl=en&_x_tr_hl=en
" The rotor of the hysteresis motor consists of the core of aluminum or some other non-magnetic material that carries a layer of special magnetic material. "
This layer of special material was of most interest. This magnetic material is somewhere between soft magnetic and hard magnetic materials.
This special material is supposed to have a high magnetic viscosity. "a property of magnetizable substances because of which a certain time is required for the magnetization to reach an equilibrium value under a given magnetizing force"
Oddly enough, hysteresis motors. are very common and such motors can be bought at flea markets.
The documented efficiency of ordinary hysteresis motors is low, 0.1 - 0.2.
But this is when powered by a conventional sinusoidal current.
I imagined extracting this material in some way and using it as the core of a transformer. There is no need for a motor if it would be possible to generate electricity directly in the transformer.
In a strong magnetic field, this material remagnetizes faster than in a weak one. The idea was to magnetize such a core with a short pulse of a strong magnetic field, and generate energy due to slow spontaneous demagnetization. Orient the domains with a short pulse, and then the domains are slowly deoriented by thermal noise.
But later I decided that the Carnot cycle would not allow getting additional energy from this process.
https://overunity.com/17535/kapanadze-stepanov-barbosa-leal-and-the-secret-of-free-energy/msg516790/#msg516790
Quote from: bistander on August 07, 2023, 09:36:29 AM
For the purposes and intent of this forum, I'd say not.
Unless of course you have your household or car running on such a device.
bi
This australian guy/guide more comprehensive ?
    The GGOE GEARBOX
  The GGOE Gearbox provides continuous electricity 24 hours a day, 7 days a week. Unlike renewable systems which are completely dependant on the sun shining or the wind blowing, the GGOE Gearbox churns endlessly and has zero emissions.
The GGOE Gearbox will be capable of being incorporated into cars, homes, and other operating environments delivering users cost-effective energy.
Enjoy endless free electricity with the GGOE Gearbox. No need to rely on local power grids, expensive power storage batteries or solar!
https://www.ggoe.org/
300 €/KW  ( 9995 AUS$ /20 KW /1,68 AUS$/€ conversion )
Let us calculate :
300 € /8766 hours = 3,5 Euro-cents per KWh costs 1 year capital R.O.I.
300 €/ 8766 hours /5 = 0,7  Euro-cent per KWh costs 5 years capital R.O.I.
Siemens Energy,department Gamesa ( Game S.A.,SA Game ) will be overenjoyed !?
Let us bring CO2 scrubbing per ton from ocean/air to the 10 €/ton range !
And local hydrogen production as cheapest 'energy storage'  :
https://judbarovski.livejournal.com/133945.html?thread=147769#t147769
O,1 US$Kg = 10 US$¢/33 KWh hydrogen ~ 0,3¢/KWh hydrogen or OPEC+ -equivalent :
                                            4,8 US$ per barrel hydrogen
kolbacict
Quote from: Sergh on August 08, 2023, 05:47:30 AM
QuoteThe hysteresis moment M g does not depend on the rotor speed. A radical way to increase the torque of a hysteresis motor is the use of hard magnetic materials with a rectangular hysteresis loop. The rotation frequency of such an engine is synchronous with the rotation frequency of the field, the efficiency is high - up to 80% [2] .
What is the material of the outer rotor of this ДП-3 motor ?    Looks like regular iron.
bistander
Quote from: lancaIV on August 08, 2023, 07:20:22 AM
    The GGOE GEARBOX
Do you have one? Using it as we speak?
Independent verification? Replication?
I saw this a few days ago. Looked it over enough. It is a scam.
bi
rakarskiy
Actually, the promised patent application: https://patents.google.com/patent/US20040239118A1/en
PS
At the input of those guys needed a motor of low power, with a very high speed of rotation, with a working mode in a long time interval, for this they turned to me. At the output was a large torque but with low revolutions, the car with this gearbox developed no more than 20-25 km / h.
QuoteIntertia constant generator   Abstract:
An inertia constant generator that needs only the external power to drive the motor upon start-up, and then achieves constant operation with residual power output by supplying partial power output to keep driving the motor, essentially comprised of a drive motor, multiple turning gears, a spindle, two belt turning gear, a belt, multiple ratio gear fixtures, multiple turning gear fixtures, and a power generation unit working on the principle of tuning gear inertia.
