Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
Goat
Quote from: bistander on October 18, 2022, 01:08:21 AM
Hi Goat,
Please define "Holcomb effect".
Also, see the simulation and analysis presented by member SolarLab which he calls LinGen, short for linear generator which Holcomb developed in a size of a smart phone battery.
bi
Hi Bistander
Maybe I should have wrote: Can we duplicate the effect that Mr. Holcomb is doing by using Toroids to get a rotating magnetic field rather than generator stator and rotor steel.  Forget the "Holcomb effect" as it was a mistake on my part.
And after thinking about it some it seems the toroid would be axial flux not radial.
My bad :P
Feb2006
Quote from: Ufopolitics on October 19, 2022, 09:22:57 AM
Hello Feb2006,
Sorry but I disagree with the above statement.
In any conventional bipolar rotor (or Exciter on a typical Generator) are wound in order that it always set a North on one end and a South on the other side, 180º apart.
Meaning North-South orientation. N<O>S
Never heard of a Generator which have all South or all North poles...
A Natural (not forced) Magnetic "chain" config (eg:N/S-N/S) would always "ADD" Forces to the Main Field.
Or simply, I did not understand the full paragraph essence...
Ufopolitics
Ufopolitics
If you look at the pictures in fig.22 it's only two magnetic poles
N and S the same as a conventional rotor, in fig.23 it's four magnetic
poles two S and two N look att the difference in winding between 22 and 23.
So more than two magnetic poles makes a cancelation and what Holcomb says is how
to overcome that cancelation.
I think that Holcombs devices works without that extra winding but at a lower output.
The easiest Holcomb build is the LinGen only a North and a South Pole but even there
He uses mu metal to make the device thinner.
He really makes magic with magnetic fields.
rakarskiy
You do not correctly represent the work of a conventional synchronous generator. Electrical engineers have such a term to put into operation or excite a magnetic field (a rotating field). This field is not in the rotor, it is in the stator yoke, the main source of its induction is the current strength from the phase wires in the stator. The task of the electromagnets of the rotor, through the rods of the grooves, is to entrain this field for movement.
The most optimal scheme for creating this rotating field in the stator yoke is a four-pole system, we observe it in the working models of the HES.
The problem is that the parameters: inductance, permeability, magnetic saturation are non-linear in the process of excitation and change. Also, these parameters will be different at full load of the generator phases.
It is very difficult to work with a closed field in a ring core through a system of switching electromagnets, it is like an EDA keeper.
Feb2006
Ufopolitics
To clarify a little I have marked the mu metal blue in fig.23.
And rakarskiy I don't understand what's your point ?
It's just a bunch of words no clarification or contribution .....
kolbacict
Quote from: rakarskiy on October 20, 2022, 12:49:09 AM
Now is the time to launch mini power plants in Ukraine. Well, you know what I mean ...
Now your time has come. Or let Holcomb donate one station as a charity or by counted lend-lease. :)
You also had a certain Andrey Ermola. Which promised to solve all energy problems ten years ago.
Why don't we hear about him?
p.s.
I would even add that to supply several Holcomb generators for Ukraine would be a good marketing ploy for the his company.  This action would be appreciated.
