Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
kolbacict
rakarskiy
Quote from: lancaIV on August 07, 2023, 12:39:25 PM
In the espacenet-page ,left side : original document ( in french )
Or please the french INPI a paper-copy ! Or print the ' original document'-pdf out !
https://www.google.com/search?q=pdf+translation+app&ie=utf-8&oe=utf-8&client=firefox-b-m
wmbr
OCWL
Thank you, very interesting just intersects with my version of asymmetry of magnetic circuits.
Galey ' cited document' :
https://patents.google.com/patent/DE1488837A1/en
The electromotive force induced according to Lenz's law Force has such a direction that the electricity generated passes through its magnetic Effect of counteracting the change in the magnetic flux that creates it seeks.
wmbr
OCWL
onepower
Quote from: kolbacict on August 07, 2023, 11:21:18 AM
We recently looked in one of them.
And also the micromotors of cell phone vibrators also do not have an iron yoke.
Iron cores are not needed and many high efficiency RC motors have minimal core material and only four to eight windings on each leg. With only four windings on each stator leg the conductor length is only an inch or so long. One would think it's very lossy but it's very powerful and efficient when short pulses/pulse width modulation are used.
The general rule is that when the current or magnetic field stops changing in a conductor it becomes a resistance. As in the picture below if we apply power to a conductor the current starts rising and the magnetic field expanding. When the current and magnetic field stops changing or flat lining as we see at the top of the curve most of the energy goes towards conductor heating. Ergo, if the conductor gets hot your doing something wrong.
This is why Nikola Tesla was always trying to shorten the duration of his impulses and using air core coils.
Tesla was brilliant and he understood that no resistance and little inductance was needed to limit the current flow so long as the impulses had a very short duration. Today we something similar and DC/DC converters have replaced transformers and current limiting resistors. Tesla also used series capacitors (hair pin circuit) to limit current instead of resistors. In this respect Tesla was probably 100 years ahead of his time.
AC
rakarskiy
Quote from: lancaIV on August 07, 2023, 02:59:34 PM
wmbr
OCWL
Here I disagree with him, in my version the current force is the cause of another phenomenon. The EMF in the conductor is only in the window of the magnetic core where the closed flux changes. If I had seen this scheme six months ago I would have accepted everything as the author claims, today, alas, I know how it works in reality.
