Interesting machine
Started by Question, May 08, 2022, 09:26:23 AM
Question
The pulse duration modulation has nothing to do with the business. It is used only to regulate/control the brightness of the lamps without losses.
If we remove the pulse duration modulation system, then the eight lamps will behave just in the same manner. That is, all four lamps of the "lower" circuit 1 and the two left lamps of the "upper" circuit 2 will glow again with the same brightness while the two right lamps of the "upper" circuit 2 will glow again much brighter. Read carefully the explanatory text in our video.
The black box is for sale.
Question
And even more clearly. (For those who are not illiterate.)
1) Have a look again at our video. The configuration is as follows:
12 V rectifier => two left lamps => black box => two right lamps.
2) The black box is an eternal and never-dying battery, which never needs re-charging and which is connected in parallel to the rectifier.
3) The black box makes the two right bulbs glow much brighter than the two left bulbs.
4) If we replace the black box with a standard battery, then this standard battery must be periodically re-charged or replaced (with new one) in order to keep bigger the brightness of the two right bulbs.
5) The black box eternal and never-dying (forever-lasting, never-needing-recharging, etc.) battery is for sale.
stivep
Quote from: Question on May 14, 2022, 08:02:10 AM
It doesn't count,
it doesn't matter
and is not important to the audience,
how much you try to defend a product or your own
money making system.
I wish you success in selling shit or gold I don't care my friend.
Physicist doesn't care much what is inside of a Black box
Every  illusionist knows his tricks.
For physicist your device "doesn't work" (= is not conformed)
or
For physicist looking at your "working" device presentation - your device "doesn't work" (= is not conformed)
unless one or at best  two factors are explained, checked, known and  independently verified.
1. what additional energy at output of the device comes from ( originates)
2. precise measurement done independently by credible  entity or  reported by number of
    happy clients recognized by community (recognized -  involved crowd)
-if that didn't happened you are still in your fantasy world my friend.
You may produce video  showing light  energy calculation, measurement,vs energy consumed ,
including equipment used to  perform it.( at best  with calibration stickers on it)
that helps to some point to promote your sale,
But if it than is rejected by measurement made by others than from position of
uneducated fool, or just a dreamer  there is only transition to rejection and accusation in your address.
Wesley
Question
stivep, you are not reading my posts at all.
I am sending again the text of my last post especially for you.
BEGINNING OF THE TEXT
END OF THE TEXT
Simply carry out the experiment described in item 4 on your kitchen table. Where is here the trick? Where is here the illusion? Where is here the cheat? What are you talking about?
stivep
Quote from: Question on May 14, 2022, 09:18:10 AM
stivep, prepare the money and I will send you the black box never-needing-recharging battery. :)
_______________________________________________________
You have full rights of  being innocently right or wrong
as long as you don't deal with other people money.
once somebody put money in you,
invests in the idea,
supports you in any way and gets disappointed
you are really becoming a "negative value"
it was a time when I was trying to say that humanity, give them Free Energy,
and all of it for free. I've got very much disappointed with the outcome.
People don't care.
they don't respect free although they want everything for free or for less.
Example:
I gave them perfectly working technology, very much explained but not in 100%,so say 97%.
It is backed  with science, facts, the practical experience, practical tests, theory, calculations, experiments,
they don't want to do it, unless it is in the form of the device ready to be purchased with an instruction manual.
So screw them all said Dr Hans  my friend and partner.
we both are interested in science, and science only, we are not manufacturers traders nor in needs to become one.
Quote from: Question on May 14, 2022, 09:18:10 AMBut you have no money as you are simply a poor hater
Another mistake that you made here on this forum
In the purchase value of just the electron microscopes in two labs the is over $1 million,
-in their actual value much less
but of course it doesn't include the value of the labs and equipment in it.
you bumped into the group of thinkers :
it is me
Dr. Roy
and Dr. Hans
if you need it then give me some time and I post here some links to  let you  verify it by yourself,
Wesley
