Interesting machine
Started by Question, May 08, 2022, 09:26:23 AM
Question
Ok, ok I am sorry.
But stivep, you are not reading my posts at all.
I am sending again the text of my last post especially for you.
BEGINNING OF THE TEXT
1) Have a look again at our video. The configuration is as follows:
12 V rectifier => two left lamps => black box => two right lamps.
2) The black box is an eternal and never-dying battery, which never needs re-charging and which is connected in parallel to the rectifier.
3) The black box makes the two right bulbs glow much brighter than the two left bulbs.
4) If we replace the black box with a standard battery, then this standard battery must be periodically re-charged or replaced (with new one) in order to keep bigger the brightness of the two right bulbs.
5) The black box eternal and never-dying (forever-lasting, never-needing-recharging, etc.) battery is for sale.
END OF THE TEXT
Simply carry out the experiment described in item 4 on your kitchen table. Where is here the trick? Where is here the illusion? Where is here the cheat? What are you talking about?
stivep
Question
stivep, simply carry out the experiment described in item 4 on your kitchen table. The configuration is as follows:
12 V rectifier => 2 left lamps => 12 V standard battery => 2 right lamps
The 12 V rectifier and the 12 V standard battery are connected in parallel.
The 2 right lamps glow much brighter than the 2 left lamps.
But after a certain period of time (several hours) the 2 right lamps and the 2 left lamps are glowing already with the same brightness and you have to re-charge the battery or replace it with a new one.
Simply repeat the above described simple experiment. Use another voltage if you like and whatever bulbs you want. (But all four bulbs must be identical.)
stivep
I don't care that is not a proof of any kind, whatsoever.
__________________________________
The primary question is:
if we assume for reason of the  thought experiment that there is the gain there than
what that energy comes from?
https://www.bing.com/ck/
1 Law of Newton/thermodynamics:
Energy can't be created nor destroyed
answer the question if you can.
Physicist doesn't care much what is inside of a Black box
Every  illusionist knows his tricks.
For physicist your device "doesn't work" (= is not conformed)
or
For physicist looking at your "working" device presentation - your device "doesn't work" (= is not conformed)
unless one or at best  two factors are explained, checked, known and  independently verified.
1. what additional energy at output of the device comes from ( originates)
2. precise measurement done independently by credible  entity or  reported by number of
    happy clients recognized by community (recognized -  involved crowd)
-if that didn't happened you are still in your fantasy world my friend.
You may produce video  showing light  energy calculation, measurement,vs energy consumed ,
including equipment used to  perform it.( at best  with calibration stickers on it)
that helps to some point to promote your sale,
But if it than is rejected by measurement made by others than from position of
uneducated fool, or just a dreamer  there is only transition to rejection and accusation in your address.
Wesley
Question
stiveup, stop beating about the bush and simply repeat our REAL (NOT THOUGHT!) experiment on your kitchen table. And report your experimental results here in this forum.
