The Real No Lenz Generator (opposite Lenz Effect) Watch Video
Started by JackJohn, June 17, 2022, 05:39:53 AM
kolbacict
How can you do not understand!
If we make and selfrotated such a simple "хрень", it will be possible to put it on a closet, in front of our eyes.
Let there be little practical use from it. But it will inspire you to new achievements. It's worth more.
JackJohn
Quote from: kolbacict on June 19, 2022, 08:37:30 AM
I think there is some truth in what you said, I will try to make a small version as you wish and I don't think it's too difficult for that I just use a JackJohn coil (my concept) with several components. Unfortunately I am very weak in electronics skills but I will still try it and as soon as possible I will upload the Device Test Video on my Dailymotion chanel .
once more
I see you are very rich in knowledge and experience maybe you have seen a stator iron core like this can you explain what the former engine stator is? because the copper wire coil is similar to the QEG design
https://youtu.be/xZKU14cRyIc
kolbacict
Quote from: JackJohn on June 19, 2022, 10:23:03 AM
Well, that's not entirely true.  I still no managed to make something self-rotating.
And Mr. Rakarsky does not want to help me with this.  :)
So I can't say anything about your video. However, I had an idea.
Since at the initial stage of construction of a self-rotating wheel, the interaction forces between the magnets and coils are small. Due to lack of experience and knowledge.
I suggest using a pendulum instead of a wheel.
Less energy will be spent on its movement. ;)
JackJohn
Quote from: kolbacict on June 20, 2022, 01:29:12 AM
In my opinion, for the mechanical version of the self-rotating device, I prefer to use the V Gate magnet concept because in that system we already get 75% free spins in each cycle. so it's just a matter of dealing with the remaining 25% and that can be done by combining the V Gate with the Flywheel / DC pulse which is already very well known for its very high efficiency or bedini coil. The task is to unite all these parts
kolbacict
Quoteby combining the V Gate with the Flywheel / DC pulse which is already very well known for its very high efficiency or bedini coil.
I did  combine this V-gate with anything.  :)
Even, do not believe it, with a double Milkovich pendulum.
I haven't seen anyone do this, I made it up myself. 8)
And I also believe that there should be no power sources, no batteries.
Here in the device below, there are no batteries, but they say that it rotates. ;)
