Graphene free energy enters the market
Started by BorisKrabow, July 14, 2022, 07:58:27 AM
BorisKrabow
Hi !
      A lot of information on graphene technologies has appeared on the Internet. Of course, the use of graphene as a source of free energy is of the greatest interest.I'm impressed with the announcements of this technology's market entry.That's why I'm posting information on this topic here.
     Market launch publication         https://www.smart2zero.com/en/graphene-energy-harvesting-chips-closer-to-availability/
  Similar Technology  Neutrino Deutschland GmbH     https://www.youtube.com/channel/UCnpMxHAh1XmUOPl0Cajnq6A/videos
   there is also a recipe for making a thin-film graphene cell (posted by an unknown researcher) :
        a finely ground mixture of 75 percent graphene and 25 percent silicon is applied to aluminum foil. The binder is a polymer varnish. The binder should be as small as possible. Layer thickness 0.1- 0.3 mm . The cell potential is 1 volt. The power of a cell with an A4 sheet area is 1 watt.           5 layers of cells gives 5 volts, 12 layers gives 12 volts and so on .
        Option 2 - self-charging capacitor. First, a polymer varnish is applied to the aluminum foil (to create an electrical insulator), after which a mixture of graphene and silicon is applied. Ready .  :)
          in the comments on YouTube I saw positive reviews about the use for several years. I did not save the addresses of the latest sources of information.
         How to Make Graphene (The Cheap and Easy Way)     https://www.youtube.com/watch?v=iZoWgoCsAm0
        I hope that many now found what they were looking for .......
                        regards
BorisKrabow
It should be noted that the graphene cell does not require heating. Electricity is produced from the heat of the environment and various variable fields in the surrounding space.
Technically there still is no product on the market but indeed this is some exciting technology that I also have been following for a while. Btw as described in the talk it's not the graphene that's doing the magic here. It's the combination of graphene and the diodes. The diodes even need to be in pairs and have the correct characteristics for it to even work at all.
Perhaps something noteworthy he mentions about solar energy that produces only 5W/m². This value is talking about the average power of solar meaning if you calculate it over 24/7 period a year long. This is a fair comparison as this device would be able to operate 24/7 at peak performance (1W/m²).
To me what's more powerful here is not it's 1W/m² average performance. But the fact this could be stackable unlike solar panels. For instance like current 3d NAND technology it can be stacked on the chip level. You could have many many more layers of this stacked and easily increase its rated output power by a 10-1000 fold. A 1000W/m² panel would be insane it would cool down the environment so fast that it will probably condense and freeze the water in the air around it and stop working.
EDIT: Would also like to share this video of the company that is trying to bring this tech to market: [size=78%]NTS Innovations Graphene Energy Harvesting - YouTube[/size]
Paul-R
Quote from: broli on July 15, 2022, 02:58:32 AM
Graphene is carbon in a fancy arrangement in thin films. How does this produce energy, with or without ther diodes?
truesearch
QuoteGraphene is carbon in a fancy arrangement in thin films. How does this produce energy, with or without ther diodes?
One possibility is that the Graphene together with the diodes is just a catalysis which taps into the "space" energy field and allows us to extract just a little bit of that sea of energy?
