What happened to Dr. Eugene Podkletnov?
Started by broli, July 20, 2022, 01:37:54 PM
About two years ago Eugene Podkletnov had an interview with Tim Ventura:
Eugene Podkletnov - 2020 Gravity Modification Research - YouTube
As part of the interview he also disclosed a video of his gravity modification experiment:
Eugene Podkletnov 2020 Experiments - YouTube
Back then he alleged that the shown experiment no longer needed super conductors and high voltages. The only special thing was the "gold/silver nano coated" rotating disc. But so far no paper or further information has been released on this.
Does anyone know what happened to him? It would seem that the experiment got so simple that a lot of researchers could validate his claim. Perhaps someone can get in touch with him and get an update?
ramset
Worth a try
Would be good to see if he advanced or honed the experiment since then !
Thanks for sharing
Will get info to admin and a few good contacts in open source
Scientific community!
Respectfully
Chet K
Thanks Grandma
Sergh
First claims Evgeny Podkletnov about shielding gravitational force:
QuoteA possibility of gravitational force shielding by bulk YBCO superconductor
Dec 1992
Shielding properties of single-phase dense bulk superconducting ceramics of YBa2Cu3O7-x against the gravitational force were studied at temperatures below 77 K.
A small non-conducting and non-magnetic sample weighing 5.48 g was placed over a levitating superconducting disk and the loss of weight was measured with high
precision using an electro-optical balance system. The sample was found to lose from 0.05 to 0.3% of its weight, depending on the rotation speed of the superconducting disk. Partial loss of weight might be the result of a certain state of energy which exists inside the crystal structure of the superconductor at low temperatures.
The unusual state of energy might have changed a regular interaction between electromagnetic, nuclear and gravitational forces inside a solid body and is responsible for the
gravity shielding effect.
What is this YBa2Cu3O7-xsuperconducting ceramics?
https://en.wikipedia.org/wiki/Yttrium_barium_copper_oxide
https://www.youtube.com/results?search_query=YBCO+superconductor
I was very surprised when I read that the technology for producing artificial aluminosilicates is close to the technology for producing ceramic superconductors.
The ceramics of such a superconductor can have a large number of micro and nano cavities.
This video shows the process of pressing tablets from powder of YBCO:
https://youtu.be/sLFaa6RPJIU?t=760
Lately Evgeny Podkletnov claims that there is no need for superconducting material for his devices.
https://www.youtube.com/watch?v=rCA_pteLdAo
What is necessary? Porous ceramics in a strong magnetic and electric field, together with the flow of charge carriers through nanocavities in ceramics?
QuoteWorldline numerics applied to custom Casimir geometry generates unanticipated intersection with Alcubierre warp metric
While conducting analysis related to a DARPA-funded project to evaluate possible structure of the energy density present in a Casimir cavity as predicted by the dynamic vacuum model, a micro/nano-scale structure has been discovered that predicts negative energy density distribution that closely matches requirements for the Alcubierre metric. The simplest notional geometry being analyzed as part of the DARPA-funded work consists of a standard parallel plate Casimir cavity equipped with pillars arrayed along the cavity mid-plane with the purpose of detecting a transient electric field arising from vacuum polarization conjectured to occur along the midplane of the cavity.
An analytic technique called worldline numerics was adapted to numerically assess vacuum response to the custom Casimir cavity, and these numerical analysis results were observed to be qualitatively quite similar to a two-dimensional representation of energy density requirements for the Alcubierre warp metric. Subsequently, a toy model consisting of a 1 μm diameter sphere centrally located in a 4 μm diameter cylinder was analyzed to show a three-dimensional Casimir energy density that correlates well with the Alcubierre warp metric requirements. This qualitative correlation would suggest that chip-scale experiments might be explored to attempt to measure tiny signatures illustrative of the presence of the conjectured phenomenon: a real, albeit humble, warp bubble.
Publication:
The European Physical Journal C, Volume 81, Issue 7, article id.677
Pub Date: July 2021
https://link.springer.com/article/10.1140/epjc/s10052-021-09484-z
