audio amplifier as a power generator (instruction)
Started by dxer_87, September 21, 2022, 03:56:14 PM
dxer_87
corrected info on modo, use independent heatsink for first transistor:
dxer_87
nice drawing od dynamic key (easier to print, Irfan View is recommended).
dxer_87
this version of keeper for our self sustain power supply may be more efficient for extreme current draw :). greetings to all, rainy day is watering my plants :).
dxer_87
pro drawing of a bulg addon. as for me it sounds better than buster (Major Hirst version) but it depends on a specified model. sometimes i was just using thing i called '3rd electric' that consists of a 300k resistor and a diode from live to pcb chassis. what you can achieve as 'sound of live' much depends on getting signal circuit and specified model (i.e. caps used).
dxer_87
An ending of an amplifier may be modified as modo (phase replication), but more safe is to use it as a 'Baby" to suck the neutral. It works different than the paulos itself (that break the Kirchoff Law and consuming neutral for left ch. transformer). I don't know if to give getting signal on input of right ch. or maybe something else will result in better sucking, but still without any input this will work. I was using in 1994 mostly resistors on this version because of lack of caps. Both will work, maybe even trafo coil there, but it depends on model. To achieve better sucking, caps in the ending may be modified for a bit higher capacitance.
If you use Paulos only to cheat the meter (breaking Kirchoff Law of closed circuit on Neutral), this may be much more efficient version. Also its self powered, so you may use excess energy to supply some low power devices. (Start from Live or Carat Trax).
