Unlocking Zero-Point Energy
Started by Feb2006, October 18, 2022, 10:13:00 PM
sm0ky2
It is important to understand that the incoming radiation is already in electromagnetic format.
This is not a conversion of thermal energy, rather (mathematically) the energy is described by thermal values for convenience.
Consider the device to be a filter and an asymmetrical diode.
Analysis of the circuit is taken from before the filter.
We can imagine this similarly to cable television using an in-line channel filter.
Prior to the filter there is every channel. (Power over cable uses all channels)
If we were to analyze the power AFTER the filter, and compare that to the pre-filter power
We find a difference in potential, at any current value.
The asymmetrical diode has a shorter mean free electron path on one side. This is how it functions as a diode.
2 pieces of metal, one thicker than the other, with a barrier between them.
Due to the nature of the electromagnetic energy being harvested:
Outside of the device it is equal everywhere. Without the 'filter', there is no potential difference.
And this energy is present even in the absence of heat. (0 degrees Kelvin)
However, after the filter there is.
And it is this internal potential difference (with respect to the outside circuit) that provides the current.
While Voltage does not depend upon the surface area, Current does.
Keep in mind this energy density of 1.7 GW / m^2 is scaled up from minuscule fraction of a meter.
So move the decimal 12-13 places to the left and you have the power output of the current device, at the size they are currently capable of producing it.
An actual large scale device has yet to be produced.
[size=78%] [/size]
sm0ky2
A macro-world device can be designed to demonstrate the  principle used to harness this quantum energy.
Take for example the power harnessing method used by crystal radio to power itself.
The FM radio band is saturating your space with energy on every channel that has a station broadcasting on it.
So the test rig will have 2 antenna - one designed to pick up every fm channel
Rectified
The second picks up only one channel. - also rectified
The potential between the 2 outputs is your harvested energy.
skywatcher
Quote from: sm0ky2 on October 25, 2022, 06:13:11 PM
Rectified
Unless you are located very near to a strong transmitter, you will not get more than a few mW with this method.
And in any case, it's not 'zero point energy', and it's also not 'free' because someone else payed for it.
sm0ky2
Quote from: skywatcher on October 26, 2022, 02:08:40 PM
I was not suggesting to use this as a "power source"
Nor that radio waves were a 'free source'.
This is to prove the technical aspects of harvesting energy in this manner.
The fact that it works (at any power level), proves the theory presented by the inventor.
NickZ
   All it proves is that you can obtain mW from a man made source, which proves nothing about harvesting a USEABLE gain, or unlocking zero point energy, from the surrounding immediate natural ambient source. Instead of from man made FM radio signals. And, as with most all other tests so far, this will end up proving nothing, about unlocking zero point energy, nor leading to greater outputs. However, I'm ready and willing to be proved wrong by actual tests, not just by wishful thinking.
   NickZ
