correa's pagd in ACTION
Started by terry muller, February 07, 2007, 01:01:17 PM
terry muller
now, some photos for you, just for fun!
terry muller
hartiberlin
Hi Terry many thanks for these interesting
analysises and pictures.
Please try to wind a coil onto your tube and see, what kind of induction
voltage you can get from this coil..
I once had a simular setup just with a small Xenon flash tube
and I could get quite some good induction
into a coil wired around the Xenon tube.
But then I lost the exact circuit diagram, cause I changed some wires
and I could not replicate this good output energy from the coil connections.
I also had some kind of feedback coil additionally, but again,
documentation of circuit diagrams are so important, so always write
down the exact circuit diagram, before you change anything.
Many thanks and looking forward to your next experiments.
Also Chernetsky did it with H2 gas at low 0.5 Tor pressure or something
simular like this.
When he did get the overunity effect, his H2 gas changed the color
from yellow to blue...or the other way around...
Just if you have the possibility, just try H2 at low pressures, this
is a very interesting gas.
But please try to put a vacuum first into your tube, before you fill
it up with H2, so you don?t get oxyhydrogen, which is very explosive !
Be very carefully !
Good luck !
Regards, Stefan.
terry muller
Hello Stephan,
A few days ago, I took time to test the tube with a co?l as you suggested it: the places of electrodes were modified as you can see it on the photograph, so that the induction produced by the discharge is optimal: you can see that it?s a kind of vacuum arc discharge here: the diagram shows you two curves; the top is the voltage of the tube (1500 volt), and the bottom is the voltage induced in the co?l: the frequency of resonance of the co?l is related to its own capacity: what is interesting, it is that the impulse in the co?l is created by the voltage drop at the boundaries of the tube: the instantaneous current is very important, but curiously, it is only the beginning of the discharge which creates the impulse in the co?l, not the rest of current of discharge of the condenser: it seems that this ?second? current is useless????? for induction:
Another thing, for the moment, I still do not have OU with the  basic corr?a?s tube: and i waste lot of time with false data because measuring instruments are often misleading: I must match up various tests to have the true values: it does not seem useful  to me to tell all these tests which I carry out: I prefer to wait to have something  concrete before publishing : but of course, if somebody needs assistance for the basic system, I answers.
Thank for your suggestions
bye
Terry Mr.
bitRAKE
Terry, thank you for the wonderful images. Your attention to detail is well respected. Are we saying that energy is present in the vacuum (potential between relatively neutral particals is not zero)? Or are we saying the vacuum acts as a different type of capacitor? These might be the same thing, but the second one can be a liaison to the first. Have you tried a neutral plate between the cathode and anode? Is the conical form in the patent important to the effect?
Please, keep posting your discovery.
Energy might not be FREE, but the universe has been building it up for billions of years - the fact that we exist means it is availble to us.
