The most efficient machine ever built
Started by innovation_station, February 10, 2007, 09:04:11 PM
acp
To reiterate what Stephan already asked. How much electrical power does your water pressure unit need? Also, where do you think the "extra" power is coming from?
Remember, power is not voltage. 600volts at a few microamps is very little power.
innovation_station
the pressure washer you see in the video uses 110v ac @ 15 amps to operate it is pushing 1.6 gallons/min @ 1500 psi
where will the extra power come from
who knows
i think that i  will increase in power from the laque of friction from  the turbine remember that speed is power all by its self so i think that the power from the pressurized water hitting an almost frictionless flywheel converts the energy from pressure to spinn verry efficiently also once somthing is set in motion it tends to stay in motion or can be kept in motion with little input once i wind it up for 1 min it reaches its speed then take input away for 1.5 min then apply input agin for 30 sec and repeate im sure it will use less power to mantain its speed
all is variable i can add more weight to the turbine for more mechanical torque i can add less pressure for lower input power i can add more generators until i find the balance point where all works at a safe speed and desired output power is achieved
i can change many things to make it work better
also remember i used 9$ bearings so what will happin if i use 1000$ berings
higher speed lower input  (less friction)
now that is about the turbine and about the generator there many overunity generators out there i have chose the muller but i have made changes to it i used 16 groups of 4 magnets  1" put them in a 9" disc i then designed and built my coils i used 200 turns of 22 gage solid copper wire and i built 15 coils for each side of the disc 30 in total each coil will make 20 + volts after 1 min of in put i have drawen some nice drawings of this generator it is verry simple and cheep to build i used no special tools to build it i will be poasting all drawings and finished pictures soon it is based on the muller generator but with my coils and layout my orignal goal was to build 2 generators 1 for each side but the costs of the magnets is slowing me down never the less i have almost finished the generator and it will do for testing pporpouses should make close to 600 volts at i dont know how many amps but i will garentee it will be amps not micro amps
pictures verry soon and many of them
is
innovation_station
here are the drawings i have been working on it is almost finished
acp
Quotethere many overunity generators out there
I see..... Well, why bother with all the complication, mess and inefficiency of using water turbines then? just get any fairly high efficiency motor and connect directly to the "overunity generator"...........
innovation_station
yes acp im sure u could but i invented my turbine for highspeed that  any efficient electric motor could never compeate with IT WILL SPINN THE FASTEST ON EARTH!!!!!
MY TURBINE
is
if for some reason you dont beleave me then build it it is OPENSOURCE  you know
you could build a 20 lb turbine for less than 75 bucks test for yourself i am
