High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
kokomoj0
Quote from: hkyle on May 31, 2007, 10:44:28 AM
Trust me that's all the watts I am going to need. ;)
My last cell put out 6-7 liters / min on 324 watts. Efficiency is the key how well you make and seal your cell.
Do you, or does anyone have data on how many litres of HHO per minute it takes to run and accelerate a 6 liter automotive gas engine?
I have not been able to find anything conclusive on it?
kokomoj0
Quote from: rapttor on May 31, 2007, 11:37:53 AM
@HKyle
Variac on a pc pwr supply... there's an innovative use of something that I know for me I've got enough of them, some serve as doorstops, paperweights .. source of already cut to length jumpers...
Well, I cannibalized the pwm controller off that little benchtop mill I have last night, and fired it up, but the output has a built in over current protection built in, which cuts out at 4.5A... I got it to run for a while at 36volts, but it heated up and then just kept shutting off... so looks like I'm back to building a ghetto pulse unit, with a encoder & disk from a printer... switching a fet... I've got an old apc ups unit that's got 24vdc out to keep the batteries charged, at a decent current.
One thing that keeps popping into my head though, is trying my variac with a diode on one leg of the ac only... giving a ->->-> & <><><>
Keep the sparks to a minimum...
-rapttor
Here are some reasonable and nice controller units i used to put on machinery that i built..  they are pretty reasonably priced too.
https://www.kb-controls.com/categoryNavigationDocument.hg?categoryId=2
IronHead
Thanks kokomoj0
3000 to 4000 liters per hour.
For the big nasty controllers and such.
http://www.electricvehiclesusa.com/
http://robotcombat.com/marketplace_electronics.html
Diode bridge Info
http://en.wikipedia.org/wiki/Bridge_rectifier
For big alternators.
http://www.electrodyne.com/index.html
For Programmable ECM and Injector Mods
http://www.megasquirt.info/
For O2 sensor
I will teach you to build signal changer
Clear PVC
http://www.clearpvcpipe.com/
For Freq Generators
eBay.com
For Metal
http://www.onlinemetals.com/
http://www.onlinemetals.com/merchant.cfm?pid=7864&step=4&showunits=inches
Just a list  this will be reposted at a later date in Phase 4
IronHead
yikes
Well, for todays tests:
I had the 18 cells conditioned and had 25.8 volts at 2.4 amps.  Had very few bubbles coming off.  I used a small but powerful flashlight to see better in the cells and it seemed as though the light generated more bubbles.  I tried it several times.  Let's see:  25.8 / 18 = 1.43 v per cell.  Faraday is 1.5  (1.7 emf - .2 heat).  Was I just imagining this or could a light generate .57 v?  It seemed to work best when shining the light directly at the plate (neg.)  Of course, it could have been just the
cccoooofffeeeeeee working it's magic.
Continued on and noticed that the bubbles did not want to break the surface tension.  They would always head for the meniscus on the plates, so much so that the bubbles coming off the neg. plate would travel over to the pos plate because of local pressure on the neg. plate, but would not break the surface in the center.
It seemed like 50 to 100X the number of bubbles on the neg. compared to the pos.
Added Naoh, 24.5 v at 5.2 amps.  Bubble size now dime and quarter sized.  Scraped some bubbles off with a pencil and lighted it, got a crackle.  Saw some whiffs of smoke.  I got down level and with the flashlite saw a standing wave of bubbles 1/2 inch above the solution.  Cool.  Waved my hand above and moved the wave.  The bubbles were coming out of the solution and were being pulled down by gravity and also pulled over to the neg. plate.  And some were 2" away from the plate!  in air!
But what are the bubbles?  Is the H trapped in a water molecule?  It was heavier than air, so it wasn't just H.  Are we splitting one H off the O?  What is H 1 O?  Or said another way when 1 H is taken away from h2O what is left?
This is fun!
IronHead
You crack me up man seeing you have such a good time with this. hehe
You have HHO  there is all kinds of stuff that come into play here for strange things that seem to happen , Heat , Surface tension, Magnetic field ,highly energized negative electrons and to much coffee.
Keep  up the study of your cell
and enjoy
