High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
Moab
Hmm, IronHead,
so do you only sometimes use the 120 Hz fullwave rectified 60 Hz wave from the grid,
or are you chopping it additionally up at 19 to 21 Khz ?
or can one just either use 120 Hz rectified OR 19 to 21 Khz pulsed ?
IronHead
You got it . Thought no one would ask .Yes it is chopped.
Switched in time with everything else.There is something about a relax mod that I do not fully understand but it works.
This all was accidental  from making mistakes in the early builds.
tishatang
Hi all
Years ago you could get a gadget that converted your car alternator to put out 120 volts for running power drills, etc. It? probably bypassed the regulator and put out AC with high hertz " It would only work for motors that had brushes.  Don't know if modern alternators would do the same?
So, If you get good production, you could still put it in a vehicle and run off the alternator?  You could put in a 160 degree themostat and cool the cell with the engine cooling system.
Just thinking ahead.
tishatang
Quote from: IronHead on March 08, 2007, 09:37:02 PM
Okay, could you post a picture or video of your control circuit for it ?
Many thanks in advance.
Regards, Stefan.
