Plasma Electrolysis by IronHead
Started by IronHead, March 08, 2007, 06:31:51 PM
aussepom
Hi keithTurtle
The process you are looking into is in use for spraying molten metals to build up shafts etc.
The coil wrapped around the acrylic tube, they use fine copper tube similar to that used in your freezer compartment, they pump cooling water though the centre because of the heat created by the high current used.
This is a form of DC induction, where the two magnetic field meet in the centre this is the area where a plasma field can be formed.
Down the centre into the plasma field area, they then under pressure they pump air with the metal dust which ever they want to use, the air with the metal dust under pressure through a narrow tube, this is centred in the middle of the acrylic tube,  heats up, the intense magnetic field in the centre reacts and in the heated air and metal dust forming a plasma field, this melts the meal dust, then is forced out at the end of the tube though a narrow opening onto the material that is to be built up.
Now it is possible, not tried to my knowledge; that if fine misted water instead of the metal dust was used maybe it could split into HOH.
This is another thing that I wanted to try but you need a heavy low voltage power supply, which I have.
The OZ Injector will use a plasma field and should give a large supply of HOH but it will be like a large bunson burner or small rocket engine flame. I do have plans to 'quench' the output so it does not 'fire up', this will give gas. The 'burner' will be use in a gas turbine engine. Water will then replace Nat gas or kerosene of JET fuel. But that is my pet project.  I will look into this HOPE cell project.
aussepom
aussepom
Hi keithTurtle
Follow up on the HOPE
  Just looked at the HOPE cell yes it seems to use the principal that I have just described, but it seems that they are using the 'touch' principal, or possibly a high voltage arc to start off the plasma field, once formed you only need to keep the power on the induction coil.
WHY do these guys rush off to patent these things, the OZ Injector basics have already been placed on the web to stop the any one from patenting it, I have not put out the fine art of it yet that makes it work, but I will eventually.
aussepom
keithturtle
Oh, good!  It looks like there be hope for this thing.  I wanna git the rough prototype together and post it.
The large bunsen is what I'm after, raw thermal potential; power input is to be minimal.
A little further thought changed the square solid center rod to a 1/2" OD tube, into which can be  inserted magnets (got 'em, neos), a small coil to generate harmonic freqs, hysteresis, or sumthin' to kick the process into warp drive...
<grin>
Gotta run fer now, thanks fer your input!
Turlte
Soli Deo Gloria
aussepom
hey
        whats the go guys don't you like me any more ???
   I can not get into the builders forum to access the plasma arc that I started????
  comming up with error 403 denighing access even on my old emails ???
as the MIB been at the site???
aussepom
IronHead
Unfortunately we have to run an emergency maintenance
Thank you
IronHead
