Plasma Electrolysis by IronHead
Started by IronHead, March 08, 2007, 06:31:51 PM
kokomoj0
Quote from: Moab on June 16, 2007, 06:48:29 PM
Robb
A fullwave bridge can be had for 9-10 bucks Youll need a 35 amp to start with. Radio shack. Or Ebay. i seen a box of 50. 25 amp bridges for 15 Usd on flea bay. At first this isnt a hard build. Like all things the tuneing can be a bear. Moab
         Lets build it
Hi Moab....
What makes tuning so difficult?  The changes with volume heat and temp ect or just the unit itself?
Does this unit work better with pulsed freq from fets than rectified line power?
IronHead
Robb077
No , many studies have been done to show that there is no harmful spectrum of light or radiation coming from a plasma cell
Robb077
Ironhead:
Thanks for the input. Finally getting some interest from an electrical engineer friend. He keeps himself so broke he went to buy bottled LP to keep his gas water heater going since they turned off the gas again. So 5000 watts of electrical heat equivalent for 15 watts got him really interested. LOL
keithturtle
robb077;
Don't get 'im too excited with those numbers... more like 5000 watts heat for 500 watts input, 10:1 return, if I read the first part right
Turtle
Soli Deo Gloria
Moab
How long would it take to build it?
Well that depends on the material you have on hand. I suppose if you had every thing, you could assemble it in 1 day. That wound be a dream build tho.
Looking for a heater.
Ok your gonna need everything from the last page "Small list". And a PWM. Bokoo fittings a gas volume controll a grundfus 3-12Gpm creculation pump. And If you cant weld stainless we'll have to find another way of building your reactor. Somthing off the shelf and cheep. Lemmy see we are going to need atleast 4'' Dia 12'' long and atleast 1/8'' thick and threaded.
Then we gonna some 4'' Npt plugs. and everything gotta be stainless.
Next if you could find a used radiator out of a car. Its going to need to be clean. Maybe 2.
Ok. next i used a fiberglass heater tank from a RV. It holds 16 gal and is redy built to serve for hot water up to 200 F. This is the water i run throughn the reactor and then i use an aluminium heat excanger. Then i recirc the 16 gal to a 52gal tank then i circulate that into 2000' of Pex. Getting ahead of myself again
Lets start with the cell. What can you find.
Koko. The tuneing is different every time you change rods/screen/or add water. If you dont stay with it and tune it as it heats and recharges She will spit and spudder. maybe even not spark up at all. so after a change out i gotta sit on top of it and watch as she comes back up to temp. Time consumeing. Not really complicated.
Speaking of heat. Your gonna need a limit switch too, I used one thats made for a boiler. Its made by Reem and cost about 10.00 if i remember. and it must have both hi and low cutoff limit. 100-210 degrees F. Google boiler heating, look at the pics and schems. replace the firebox with our little reactor. That is the best way i can explain it with out showing you Pics. Which i will do later. remenber you can scale this bugger way-way up if you wanted to..Back to work for a bit,, Moab.
