New vids on Stan Meyer!
Started by buzneg, March 17, 2007, 03:18:06 AM
h20power
Nice going Ironhead, keep the movement alive.
I posted this awhile back: The effects of Vacuum on electrolysis
Here is the math of the process: at 1 ATM and 298K the energy requirments are;
W = PΔV = (101.30 x 10^3 Pa)(1.5 moles)(22.4 x 10^-3 m^3/mol)(298K/273K) = 3.715 KJ  (this is part A to B on the graph area under the curve)
At .2 ATM and 298k the energy requirments are;
W = PΔV = (20.260 x 10^3 Pa)(1.5 moles)(22.4 x 10^-3 m^3/mol)(298K/273K) = 0.7431 KJ ( this is B to C on the graph area under the curve)
At .1 ATM and 298k the energy requirments are;
W = PΔV = (10.130 x 10^3 Pa)(1.5 moles)(22.4 x 10^-3 m^3/mol)(298K/273K) = 0.3715 KJ (end of graph)
Notice the change in energy needed to break water down . You are not going to find this in any books for I figured it out. This applies to Faradays electrolysis, not too sure of it's affects on Meyer's work.
I am nolonger going to engage Tripled in idle conversation, for it is fuitless and to the point a foolish waste of time :o. He has nothing too teach, just full of misinformation intended to divide and confuse people just starting out in the movement >:(.
P.S. good work Ironhead.
Tripled
Quote from: h20power on April 04, 2007, 01:29:29 PM
You have a sad tendency of trying to get people to do what you want them to do, don't you?
I seem to remember some other people in this lifetime that had similar dreams of grandure, let me see.... yes one comes to mind:
Charles
Now go get your diaper changed and leave some of these "honest inquiring minds" alone.
Tripled
IronHead
Yes ,the box to the right is a 36 volt AGM battery , current is about 10 amps.
Plates are like this  + nnnnn  - nnnnn +   this works very well and is producing more gas than anything I have seen in this type of direct cell . Meaning a cell that is not pulsed or built like a cap. No electronics on this one. I have found that with this little motor cap design that the gas is stronger  , more bang.
Meyers has done great work but I am producing more HHO in a small format with another design on the High Voltage HHO page. More I say than I have seen in his videos.
Although I have no Idea what he was producing with his modified spark plug laser cell.
I am now thinking about this whole laser idea to increase production.
I did the alternator deal years ago, works very well with good fuel outcome.
My advantage is no kids no wifey
Just Build It
IronHead
Tripled
Quote from: IronHead on April 04, 2007, 01:42:04 PM
Plates are like this  + nnnnn  - nnnnn +   this works very well and is producing more gas than anything I have seen in this type of direct cell . Meaning a cell that is not pulsed or built like a cap. No electronics on this one.I have found the with this little motor cap design that the gas is stronger  , more bang.
I did the alternator deal years ago, works very well will good fuel outcome.
Just Build It
IronHead
I think if you go through his papers you'll see it's all in the "Taper" design of the injector, hence the "explosive outcome" inside the cylinder when released.
Do you think a "True" red LED would have the same effect on increasing the "infared energy" within the "atom" "molecule"? ;-)
Tripled
IronHead
No but I build till I get it right. I will try anything I can get my hands on including many different light sources at least till I know the correct spectrum and build a laser accordingly .
Here is a short production video  sorry the cam is dieing . I light this and it is a very large strong bang , will ring your ears for awhile.
The cell is alittle hot right now about 120*F
