Source of energy, Testatika
Started by Lycanthropist, April 13, 2007, 04:01:40 PM
gauschor
How will you know it takes energy from scalar waves? Can you explain a little more, because this assumption sounds very fuzzy to me.
Maybe the only trick of the machine is, that they found a way to release static electricity as continuous flow and not by a short lightning (as is the nature of static electricity). Also I recall from a written interview that Baumann himself said that the trick is to NOT let the static energy discharge itself immediately.
Though I don't know how this could be achieved. If you put a resistor in the wire it has no influence because the static electricity omitts the resistor. The static charge seems to be on the surface of the wire, in comparison to the elcetricity from batteries, which provides the flow of energy within the wire itself.
Now if there was a way to convert the static energy from the surface into the wire, it might work... Maybe this could be achieved with the magic of magnets (there were at least 2 U-shaped magnets in the Testatika), but again how should this work? I could be entirely wrong too with my way of thinking though...
Very unfortunate that no one has ever revealed the principle of the Thestatika, because I believe this device is the only one out of hundreds of so claimed overunity devices which would actually work.
Steven Dufresne
Quote from: gauschor on April 29, 2012, 05:32:41 AM
For me the answer to this is easy. Other than the use of radioactive material (which I hope isn't the answer) what else but energy from scalar waves could account for the videos we see of 3kW continuously coming from the 3kW machine or 100W from the single disk small machine? Assuming it's not a hoax of course. (I tend to use the term vacuum energy but it's the same thing.)
He could simply have been talking about one aspect of the machine. Since most people on seeing the testatika think Wimshurst machine where you do take electrons from the disks, he may have simply been saying that that's not the case with the testatika disks. That's the way I've always interpreted that. Plus, if you release the static electricity slowly then you don't get 3kW. Also, you had to supply the energy to build up that static electricity in the first place so that's not a solution as to how it works.
-Steve
http://rimstar.org/sdenergy/testa
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
gauschor
Indeed, it could only be a part of the system. Also I have heard once that the electrostatics is only used to drive the discs (which is claimed in some video to have very very good bearings. Since the power of electrostatic attraction/repulsion are very weak this would be an indicator for it. And this is only possible (as well as another indicator) because the discs have no resistance, for the so called "Taster" do not touch the segments at all). Yeah, indeed the power could come from somewhere else. Or maybe they can produce scalar waves with the machine? I'm still not convinced that they take scalar waves from the earth, but rather produce them within the machine itself.
Btw. I just looked for a definition of scalar waves and found some article in peswiki which seems to be an interesting lecture for this evening: http://www.peswiki.com/index.php/OS:Tesla,_Meyl,_and_Jackson%27s_Wireless_Aetheric_Power_Transmission
Low-Q
I did read the initial post with the balloon example. These balloons works like an electric capacitor. I did happen to experiment with a doubble capacitor many years ago. This capacitor was extracted from some military equipment back in the early 90's. This psrticular capacitor was a doubble capacitor - two capacitors in one can. When I charged one, I could take energy out of the other.
The principles of build was 4 layers of aluminium foil (For a single capacitor you need 2 layers). I experimented with this 4 layer capacitor and found that I could use this capacitor as a DC transformer. One capacitor had approx 4uF and the other 10uf - in one unit. Depending on which capacitor I charged, the other capacitor had an output voltage approx equal to the difference in capacity.
However, I also found that the energy in = energy out (approx), and the output voltage dropped when loaded, and input current stabilized at a given value at constant input voltage. I cannot remember the actual readings for current and voltage.
Vidar
andrea76
Like Hendershot when apply one motor at the output ,that burnig out. the type of output current is  the same: DC+HF component.the two frequency mixed together generated an third frequency in resonance with the E.E.M.F.The magnets are used to rectifing the flux.in ALL bauman's device have magnet. in the report of two engineer Sauder and Sniker Baumann make the capturing device with one magnet , one loop coil and two plates.probably the machine running in the adiacent room again.Bob  Boyce said the flux operated in 100 feet of radius....
