Information on CONTROLLER FOR TPU!!
Started by Bruce_TPU, April 24, 2007, 03:55:12 PM
Bruce_TPU
Sauron
Quote from: btentzer on April 24, 2007, 03:55:12 PM
P.S.  Don't forget, the first one of you to get this working sends me a controller with coil.  Thanks!
Seriously tell me youre kidding...
Bruce_TPU
Sauron
Quote from: tao on April 24, 2007, 05:07:16 PM
In addition, in your first long post on the TPU, you are quoting all these quotes of SMs, but guess what? Many of those supposed SM quotes that are the basis of your theory, aren't even from SM!
correct.
it's a good thing to know what he said and what not...
so basicly btentzer want's somebody to build the device which is very very,hard work and then when they will finaly get it working,just send it over to him like here ya go...
HAHAHAHA
bob.rennips
Quote from: Sauron on April 25, 2007, 02:02:00 AM
correct.
HAHAHAHA
Btentzer is a complete joker.
Of course the TPU causes more electrons to move around at a higher speed. This is after all what it mean to have a high voltage, high current output. This is a known. But becuase he has no knowledge of electricity, he assumes this is some great shakes revelation that only he has been able to decrypt from SM texts, lol. He doesn't even understand that frequency is a measurement!!
