Proof of concept - perturbing a static magnetic field
Started by bob.rennips, May 30, 2007, 12:57:25 PM
0 Members and 53 Guests are viewing this topic.
FreeEnergy
Quote from: Jdo300 on June 06, 2007, 12:40:15 AM
Remember, it's the changing field we are after, not the strength of the field itself. So if we can kick even a weak field all over the place very quickly, we might get the results we week.
what you say goes so well with this...
http://www.overunity.com/index.php/topic,2390.0.html
karl
Hello Finders,
what you want to do is building a kind of stationary newman machine.
Have a look at the newspage of Stefan.
Someone has attempted a good example again. A working model out of nothing.
The main part of this kind of negative energy collector is a spark (plasma).
No discrete parts are used as diodes, transistors and so on.
Stefan has postet this 1998 at JLN labs site http://jnaudin.free.fr/html/NMac1118.htm
This machine consists basicly of a big coil (the bigger the better), a tuned sparkgap and a blocking device to direct the backward current.
At the right tuned distance the color (frequency=E-Level=tuning) of the spark change from blue (discrete spectrum, maybe a line of oxygen) to white (full (most)spectrum) and is making a hissing sound.
This is the electronic-hit-part of the future and the past.
The Teslas use different discharge tubes filled with H2 or N2.
I've found such tubes some time ago at ebay.
The are used to work in front of wimhurst machines (is a light going on in your head?) to show different colors of discharging gases.
This is the real tuner.
H2 has a continious spectrum!
H2 is receiving a continous spectrum!
The sun is sending out a continous spectrum!
Evey particle is tuned in a continous spectrum.
Every Molecule could be replaced by a frequency (actual science: Using frequency as catalysator).
Thats it.
The cat is out of the house.
The mice are dancing on the table.
So what I mean Stefan and all other finders:
This is a kind of tuner for a special spectrum and a kind of coupler between discrete energy levels (light to electrons and backwards).
You know that plasma is called the fifth (element) state of energy.
Most of the materia of our cosm is in plasma state.
You want to couple in this mass. The best universal and universallegal way to fullfil your wishes.
!This are just suggestions. I'm not a proofer, but think about it!
Please open your minds and start to see: over unity is only possible by thinking on cosmic levels. Oder ist das nicht so?
Every particle in the 3d space is affecting every particle in the 3d space.
Simply by overlapping all influences of all roompoints we get the momentary situation in static and dynamic fields. This is the basic of our common computersimulation programs.
The biggest mass is in plasma state. The biggest content of energy (gequantelt oder nicht) is sending out energy because of the fact, that plasmatic materia has more energy as motion, and therefore heat and preasure and speed, as materia which is resting more in one roompoint.
Is this clear?
We should couple to this mass of frequencys by sending out a em pulse with our coil (creating a vacuum) and receive a modified pulse (filling the vacuum) after a while.
Stefan: is it possible that we change the "Verweilzeit", the time of duration of our pulsed mass in the space and therefore the time of the em-Quant in space by adjusting the sparkgap?
Is the energy quant able to collect energy and mutate to a harmonic em object which is rejected by the coil (blow-suck-effect)?
Yes, I think so.
Best wishes to all.
Kar Funkel
karl
Earl
Bob,
please PM me the datasheet for the IRS2217PBF.
Thanks, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
bob.rennips
Quote from: Earl on June 06, 2007, 07:29:38 AM
Bob,
Thanks, Earl
My mistake in the original message. I incorrectly stated the high side driver as IRS2217pbf. The high side driver is the IRS2117PBF.
