Proof of concept - perturbing a static magnetic field
Started by bob.rennips, May 30, 2007, 12:57:25 PM
0 Members and 38 Guests are viewing this topic.
karl
Dear Mem bers,
I've studied the patent for some days.
I'm also a patentholder and I wonder about the missing workingprinciple.
What's the influence of the RND shifting of the pulses?
Should it be a matrix correlator which works on cosmic RND influences?
Is the correlated frequencypattern of two RND sequences a new form of super-RND?
My copy is not verry good. Are the lower coil ends crossed or joined at thje point where also the earth (mass) is located? or is the first coil looped back to the generator and the second coil grounded to earth?
There is a important link to the "universal magnetic field" includet in the beginning of the patent. In this case our permanent magnet is the earth's and therefore the sun's magnetic field which is linked but which is never constant. All cosmic influences are coupled and amplified due to this field.
What I mean: The main magnetic field of our solar system is generated in the sun's inner reactive shape. This shape and therefore momentary poles changes every moment. two of this poles are stretched out to the earth poles and communicates in this way with the gravitational center of the earth (Fe+Co+Ni+...who knows).
What we can measure is a superimposed static field. Is it real static? or is it influenced with numerous sub-Informations (E as a stream of bits or trits(extra thread needed)).
How can we link to this gravitational field? How can we extract the information behind this wall of static?
How can we determine the information (data) of a 4 wired blackbox?
For many of you a book with seven locks: taguchi
He uses natural mathematic principles to describe ways to identify systems and find factors to influence them.
Yes empirical science is real and is used to optimize systems due to some interesting ways.
Please feel free to inform yourself about this topic.
An other way is to pulse a system and get the impulse-answer which gives you more than enough information about it's momentary situation which could change also due to the pulse, but this principle works in static electronic design.
You can use this information to perform a second action (x2.5 as stated?) and coupled anyway to extract or tune in.
I know my mails are more intuitive than exact, but maybe thats the key.
But what's the influence of the superimposed RND?
What's the RND generator? A kind of sensor what's comming in next?
It looks like a magic generator, a reviewer?
Or was it again a project to get money from sponsors?
The RND itself is the interesting part of the configuration. I always tried to build pendulums with superpoles, but also the superpoles find their point of lowest energy in the system. Is it possible to move the resting magnet in an RND way so that it uses the energy of the pendulum to move to a random position and therefore changes the resting configuration over the time?
Then high grade mathematics or purely intumatics is possible. Chaotic systems which get's their energy from super-chaotic influences.
My next mail should be about "How to build natural RND generators and how to utilize them to extract useable electric energy from the matrix."
But before my computer get's again a headache i'll send this mail out to the cybersea.
Best wishes to Stefan and all the finders.
KArFunkel
karl
Again...
is there a way to "lock in" the em fine structure of our solar system, including our basic planetary situation or multi vibratory influences by a kind of electronic "chopper" system?
Did a defined and sensed RND value include more information and therefore discrete E-levels, as includet in particles as we know?
Are this discrete levels natural numers or do we have to think in relative numers as 1/2?
As known from trit's (similar to bits) some informations or sequences of informations could carry more strutural informations by viewing it's last, momentary and next value, a kind of checksum. In this case we are talking about the checksum-electronics which measures a static M-field of the earth.
Next question is: (hen-or-egg-first-principle) what is the basic energy form of materia and all other manifestations? E or M, expansion, implosion or maybe ether (resting).
All over all it should be a little bit of all, mixed together and stired well.
How to overcome the checksum and make them (E, M, hen and egg) moving to my f...... electronic meter?
The philosophical answer is: it's the cock which was first, because it's the beginning and the end of the logical progression.
The cock in electronics is the ether and it's resting, but it carries periodically changing informations of what has been and therefore knows always what will come. This is our mastermind. How to convert to usable energy? An endless magnetic tape, carrying the last information, but superimposes the actual situation to know the next step.
So far in the interpretation of the proposed patent: A local R/W data acquisition head with ou properties....
starcruiser
@Karl
From my take on this patent the control electronics (I assume this is what you are speaking of) indicates an amplifier and a randomizing generator to change the levels of the pulses.
The main theory as I see it is to pulse the magnetic field (either permanet or electrically induced) and gain amplification from it by maybe tapping the ether.
Sharp gradients or pulses are required (sharp rise time, or on/off if you will) to generate the effect. The output is derived from the pulses voltage delta (the difference between the high and low pulse values).
We are looking to determine if this actually does work by performing the build of a similar device but using a control system to deliver the required pulses. The control systems we are thinking of will be synchronous as well as asynchronous, the patent stated either will work, so some are pursuing one path and others are pursuing the other. I myself am pursuing async pulsing using a blocking oscillator design using the control coils as part of the oscillators design.
I say have a go at it and see what you get if you are so inclined.
Regards,
Carl
bob.rennips
Having duplicated Otto&Jason's driver/mosfet combination I've now got a much better setup. The main difference other that using a low side driver and not the high side driver, is the addition of two decoupling capacitors directly across the power inputs to the driver. This removed much of the rubbish and I was getting much crisper square waves when entering high khz 500K+.
I've also noticed that when applying a larger 24V across the coil to generate the static magnetic field, that the ability of one coil to induce into another coil is cut in half, REGARDLESS of the direction of current applied to generate the static magnetic field. In other words it doesn't matter whether N is top of the coil or bottom of the coil, they both have the effect of reducing the coupling between the two inducing bifilar coils.
I expected this to happen in one direction, but thought that in the other direction there would be an enhancement.
starcruiser
Regards,
Carl
