Proof of concept - perturbing a static magnetic field
Started by bob.rennips, May 30, 2007, 12:57:25 PM
0 Members and 38 Guests are viewing this topic.
brnbrade
Hi
The permanent magnetic ring on the outside of the pvc tube. The station was FM stereo.
More thinks that is relevant.
Mine to think it is, the primary works as electromagnet of the pulses of the sound frequency.
A diode rectifier was put in the outlet of the walkman for not having tension return.
Tks
chrisC
brnbrade  :
I don't have a good drawing tool. Is it like this? What is the FM frequency?
chrisC
Bruce_TPU
Hi guys,
Remember that story I heard not long ago?  It was a FM radio as well.  So I agree also, that FM is important.  A diode, good thing.  Was the magnet near your wires, or setting right on top of them?
Truly amazing to hear two such similar stories.  What is different about those waves than the waves we are now sending into our ECD-TPU's?
Do you mind working with those of us who would like to replicate this, brnbrade?
Good question Chris.  What was the station number?
brnbrade
Quote from: chrisC on June 24, 2007, 02:19:37 AM
brnbrade  :
chrisC
chrisC
chrisC
Great. Thank you for clarifying! Looking forward to more results from your experiments.
Thanks
chrisC
