Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
Humbugger
Post deleted by Babes In Black to save annoying scrolling for those who care to adhere to the topic.  This way, you can go right to Ash's post without ever seeing any distracting pictures of Morgan Fairchild in a nice black evening dress.  We return you now to your regular programming.
   (the next post is actually pretty darn cool to watch, although not really an energy problem panacea)
I think Ashtweth got the idea to post it subliminally when he saw those gorgeous robust Fairchild curves
In fact, I think that little smiley guy rolling his eyes up here is hoping I'll put her back...sorry smiley guy!
ashtweth_nihilisti
For those who like to stay on topic.. ::).
Stuff given to me by email
check out the attached video.!!!If this doesn't prove that using gravity but also putting a weight into a radius gives you added gains then I give up.The ball has further to travel and yet will increase in speed gaining greater kinetic energy than a normal straight fall
" look at this video of the 2 balls rolling, and she immediately said the rail is not a perfect curve, and the beginning of the semicircle is shaped differently than the other side of the curvature.
Heck,  there is the clue to the bonus energy, , This is the real thing for advancements if you can see it."
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
Humbugger
Quote from: hartiberlin on September 09, 2007, 07:28:51 PM
Quote from: Humbugger on September 09, 2007, 07:22:49 PM
Stefan
I want to hear how Charles arranges a whole number of ball receptacles at 29 degrees each yet evenly around the wheel.
I have been accused of inappropriate use of ridicule.  It is only fair that I be shown exactly why the idea of building the wheel with 29 degree increments is not ridiculous.
Then I will voluntarily ban myself, cut off both my hands, pour the remainder of the Glen Livet into my eyes and light it on fire.  I promise.  And swallow the pill Hans is supposed to be keeping.
Humbugger
Hum
you still don?t understand...
probably you missed the physics lesson where the torque arm
calculations was done...
Of course the wheel has slots every 30 degrees.
Only my right left ball sits at 14.5 degrees above the horizontal plane
4 x distance away.
Very easy to calculate all the torques as I have done.
No more need to ridicule.
Still 3.87 to 3.73 advantage at 14.5 degrees and
when the red ball has gone down to the horizontal plane,
the advantage rises to 4 to 3.73, so the yellow balls
are lifted faster !
I can do trig and add torque moments.  I made a mistake in thinking you had proposed putting the cups at 29 degree increments because I refused to believe (and still do) that you could possibly still be claiming you had 29 degrees to work with after all that had been said about that matter.
Indeed, for a 4:1 setup, the exact number of degrees you have with no SMOTs and zero slopes on the ramps (your best case yet unrealizable-in-practice conditions, you have, to four places, 28.9550 degrees, not 29.  You must also include the 1.0450 degrees during which no ball is on the wheel and subtract that appropriately.  That's 1.0450/30 of the time where the machine will want to run backward which equalizes your calculated forward advantage ratio and cancels it.
I apologize for misunderstanding and thinking you would propose putting 29 degree spaced cups on the wheel.  Sometimes I have no sense of what your reality limits are.  When one opens the Pandora's box of rejecting basic laws of physics and thermodynamics, one loses a lot of assumptions that provide a stable common ground for discussion.
I respect your knowledge and intelligence but I have no predictable sense of your beliefs and which physical laws you respect and accept, since you seem to be "arbitrarily selective" based on the context in that matter.  in your position, I can understand that.  I also get confused when you say things like "my right left ball", as above.
I'll try harder to refrain from outright ridicule.  It does give the impression of pompous arrogance.  Sorry.
Humbugger
rMuD
Quote from: hansvonlieven on September 09, 2007, 07:56:04 PM
G'day rMuD,
Ever heard of Cavorite??  That is the shot here to make this thing work. :-)
Hans von Lieven
I hear White Powder Gold will work too  :)
rMuD
Quote from: ashtweth_nihilisti on September 09, 2007, 09:10:34 PM
impressive, I was almost fooled by it
I see that the stop at the end of the ramp is of the same height
but the last frame shows the near ball lower on the track to the back stop
though the track appears to be at the same height at the end.. the track is wider giving the extra downward force
I completely recant what I said, I said things before I confirmed them, that video is absolutely true and would happen
