The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
EMdevices
Ok, you can even see the orange wire crossing upwards to reach the top tab.
I know we can't prove a connection from a photo, but I don't see any blatant deceit... yet.
I'm just hoping he comes clean on the yellow wires down bellow.
EM
Bruce_TPU
Someone tell me I am wrong and I will erase my prior statements.
hartiberlin
What role could the 2 alufoils per rod can play ?
As he thus shields the electric fields from each coil, but not the magnetic,
maybe it is a key to just have the electric field for a transformer effect but not
the electric field ?
What about eddy currents inside the alufoil ?
Bruce_TPU
@ EM
It would appear to me that the two orange wires are behind the bulb.  Look close, and you will see nothing on the three prongs except for the two jumpers.  We need more clarification from brnbrade, how everything is wired.
Cheers,
Bruce
wattsup
@btenzer
Keep cool.
The battery lines are going to the yellow going to the terminal then to the two coils in mobius.
The orange are going to the light along with the two probes from the meter.
OK you can't see the battery wire completely going to the yellow but this is only a lack of overall detail in the picture. Plus if you consider the angle of the yellow versus the battery wires, we can presume they are connected otherwise the battery wires would simply fall straight down off the side of the table.
Also, there is no sound input on this test so he is producing DC-DC and that's why the meter is at zero because he is on the AC selector.
@Brnbrade
Whenever you take pictures it is important to show all wires to be on the table and not falling off the side.
Be carefull if you plug the sound and produce the AC it could blow the bulb.
Good work.
