The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
Unicron
And what about the cap not connected now? is that not needed now?
bob.rennips
Quote from: EMdevices on July 02, 2007, 10:22:37 AM
Bruce, why don't you anotate my zoomed in photo.  What do you mean?  Place some labels on it.
I would think if he wanted to trick us he would use the yellow wires, but you never know.  Let's hope he wasn't out to have a good laugh on us.   :D
EM
Bruce - P****D - now there's something I didn't think I'd ever see!
But seriously it's not nice to think you've been had BUT I don't think this is the case.
Cheer up - ask for another photo of the whole setup and see what gives.
I think it's possible brnbrade used the aligator clips to also hold onto the stranded wire of those two connections you don't think are connected. If it's a con it would be MUCH easier to make the connection obvious and connect a 12 volt car battery to those yellow wires...
It's impossible to solder to the leads of those lamps. I've used aligator clips from my scope/freq. gen. many times to hold things in place when I want to try stuff out.
Besides it fits in too well to the stuff I'm currently experimenting having now heard about the insulators. Pulsing an electric field held on a coil does produce some interesting hash and noise on an oscilloscope...
Mannix
Stefan,
Just to respect Steven can you move this to somewhere other that Steven Marks TPU devices.......it just aint..and has no place here .
Bruce_TPU
Quote from: wattsup on July 02, 2007, 10:39:13 AM
@btenzer
Keep cool.
The battery lines are going to the yellow going to the terminal then to the two coils in mobius.
The orange are going to the light along with the two probes from the meter.
@ Wattsup
Cool and reasoned.  I just would like clarification to all of us how the orange wires are connected to the light.  If through the probes, fine.  This is all I want to know.
Cheers,
Bruce
EMdevices
Bruce, please,  I think you've been griped by doubt.  Take it easy.  Let's wait and see what our Brazilian friend has to say.
Wattsup,  thank you, you clarified the scope reading.  DC in DC out.  I totaly missed that.  Thank you.  My experiments now mean so much more  !!!!
EM
P.S.  See the photo, it's on DC (from the previous photos)  and he left it on AC in the lightbulb photo, too exicited to show us,  forget the meter reading he thought, I HAVE LIGHT !!!!    :)     I would of done the same thing.
