The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
supersam
hi all,
am i misinterpreting something or reading something into this from another thread that bruce was posting on.  the thing that caught my eye was the idea of basically trappong the bmef between two diodes.  is that right or what?  once the diodes trap the bemf then it suddenly spikes and is trapped until the second coil is shorted. then the output which was 1.5 volts dc in is suddenly 52 volts ac on the second coil.
"DAMN THE (AMP) TORPEDOES, FULL SPEED AHEAD!"
lol
sam
ps:  shuttin up shuttin up.
Bruce_TPU
Quote from: supersam on July 01, 2007, 06:16:45 PM
hi all,
lol
sam
@ Sam
bob.R's thread is the info about the diodes.
@ Rich
Great idea!  LOL  none of us thought of that.. I sent brnbrade the message.  We will see.
@ All
Regardless the outcome of this thread, be thinking, "opposing identical signals/different sources, slightly out of phase, one from the other."
Cheers,
Bruce
EMdevices
Very interesting developments !!!
EM
supersam
bruce,
sorry for the confusion. on my part, but does this possibly have something to do with brnbrade's device, or his results?  are there capaciteance issues?  what frequency ac are we seeing?  how many watts is the stereo putting out? what is the max output of the stereo unit, and where waws the volumn set?  gosh i wish i was there live!  it is looking like everytime i'm not i may be missing history in the making!
KEEP UP THE GREAT WORK!!!  and get back to my stupid questions when you can.
lol
sam
ps:shuttin up shuttin up.  if i can
Bruce_TPU
Quote from: supersam on July 01, 2007, 07:27:53 PM
Hi Sam,
Yes, this thread was made on behalf of brnbrade who asked that I assist him.  His English is not the best, and he is a youth.  So I promised to assist any way possible.
I do not know if brnbrade ever saw the patent talked about by Earl and Jason.  He can answer that.
Watts the stereo is putting out is a good question.  We have no answer at this time.  I measured the voltage on mine sometime ago when I tried to build his coil about a week ago.  At full volume, the voltage was about 235 mv.
Frequency AC is a good question.
Where was the volume set, unknown.  I asked that also, we will see.
If someone/anyone could post what type and size of wire they think the thin braided primary is, that would be helpful for replication.  It looks to be easy to replicate.
Earl gave a drawing.  There is a speaker magnet on end behind the coil.  Wrap 12awg solid first.  number of turns on the first post.  Directly on top of the large wire, wrap the thin primary.  He had said 1000 turns on another thread.  yesterday he just said, until the wrapped wire is equal to the diameter of the air core.  Mobius twist on both ends, of primary to opposing secondary.  Two coils are needed of course.
56volts AC, with no oscillations
250volt AC with.
2 1.5volt batteries.
Cheers,
Bruce
