The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
jacob
Quote from: btentzer on July 02, 2007, 04:47:02 PM
Jacob,
If you  saw the orange wires soldered to the bulb leads, that does restore my faith, very much.  I am looking for some aluminum for I am going to build this two coil deal this week.
And then I will know.  I think there is sufficient information to replicate.  We just need to know if he still has the capacitor between the batteries and input.
Cheers,
Bruce
According to the pictures, it seem to work both ways: with or without the capacitor. In any event, if this setup is tricked, and that would be a very stupid thing to do, it would be at the junction between the battery holder wires and the yellow wires. The picture let us suppose that the batteries shown are the power source, but since we can't see the connection, the power source could be something else.
Jacob
brnbrade
chrisC
Brnbrade:
Can you please give us a higher resolution picture (say several megapixel). At this resolution, I can't even read the voltmeter? Please, and better if there was a schematic of where the Caps are?
chrisC
Doug56
Brnbrde:
D? uma olhada em suas mensagens privadas (PM).
Abra?os,
Douglas
Bruce_TPU
Now THAT is impressive!!  ;D
Brnbrade,
That is without the radio, so I take it that it is producing 56 volts AC??  Can't read the volt meter either.
How did you start it up, the batteries?
Happy Days!  :)
Bruce
