The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
brnbrade
brnbrade
Quote from: brnbrade on July 02, 2007, 09:40:46 PM
Quote from: hartiberlin on July 02, 2007, 08:36:31 PM
@brnbrade
what kind of iron rods did you use ?
Are these some kind of welding rods ?
Are these thoriated rods , so do these contain radioactive
elements ?
2. Did you use alufoil or aluminium tubes around the coils ?
Many thanks.
Hi Stefan
Iron
No.  common iron
elements ?
no, I will put pemanente magnetic in the core in the future
Alufoil
Yes,  Core -> insulating -> aluminium -> insulating -> fine wire coil -> insulating -> aluminium -> insulating -> Thick wire -> insulating -> enjoy
Many thanks.
Hi ,
many thanks for this information !
That really helps !
Now we can try to replicate it.
How many turns of wire did you use ?
In one posting was said 35 turns ?
Is this the big red wire ?
How many turns does the fine wire have ?
Many thanks.
Bruce_TPU
Good job brnbrade.  I too will begin work on replication asap.  EM is hard at work also.
Do not get frustrated by our doubts or questions.  What you have going is awesome and we are excited to have you share with us what you have discovered.
Thank you.
You have it hooked to the exit of an stereo amplifier.  Now that is interesting.
@ All
Funny thing, I remember SM telling all of us to use mosfets to reproduce waves as if they were mini tube amps.  I have said that about, Oh, 20 times or so.  But this is coincidence I am sure...  ;)
@brnbrade
Do you start the oscillations with the amplifier?
Happy Days!  :)
Bruce
Hi brnbrade,
try to see, if you get any voltage between the 2 layers of alufoil.
Did you try to shortout the 2 alufoil layers or did you insolate it versus each other ?
I guess there could develop some kind of voltage between the 2 alufoil layers
in each rod setup and this might be a needed "stray capacitance" that might be
very important for the energy output.
Regards, Stefan.
