The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
CodeWebs
I made this setup on one piece of rebar and i found that my results are very like those of wattsup.  I had just a 9-volt battery connected to the device (everything is made as stated on post one for the most part, except i used scotch tape for the insulator and one solid core) and the volts showed around 8 volts to start, then dropped down to nearly 0 then began to climb up again.  I did not think much of these results, until i saw wattsup post similar results.  I then connected the 9-volt batter and a capacitor to the unit and the same thing happened.  I disconnected the 9-volt batter and the capacitor's voltage dropped to nearly 0 and started to climb back up to around 1.4 volts and then stopped changing.  I'm not sure what that means really, to be honest i just stumbled onto this post as i was looking around and decided to try and build it.
Please Doug,
could you use a software oscilloscope for your soundcard to see,
what kind of voltage are there on your coils ?
Here are many free software scopes:
http://www.tech-systems-labs.com/test-software.htm
Looking forward to your tests.
Many thanks in advance.
Regards, Stefan.
P.S: Please, for not blowing up your soundcard input
use a foil capacitor of at least 1 uF( no electrolyte cap)  in series at the input of your soundcard,
so it will not register DC input voltages.
You can measure the DC components later, if you know,
what kind of frequencies there are involved.
Please also try not to ground your PC,
so you might need to modify your AC grid power supply cable to the PC
by isolating the grounding connection.
! Be cautious then , only use this temporarly to measure this
coil setup as the grounding normally is there to prevent
electrical shocks from loose cables inside the power supply !
You do this on your own risk.!
brnbrade
Bruce_TPU
@ BRNBRADE
Why is their coil 2 volts and yours 250 volt?
HOW is their coil different from yours?
Bruce
wattsup
@stefan
I know as much about my scope as I do about crows' feet. I put the Div on 1 because could not see anything otherwise.
Here are some shots. I am putting a few because the scope keeps shifting from one form to another. These shots give you a good range of shifts. The scope is well focused.
@Brnbrade
So am I!!!!!! Thanks.
@btenzer
I have a feeling the fun will be to figure it out. It won't be long.
