*The Study of the Practical Mechanics for a Working TPU*
Started by Bruce_TPU, July 05, 2007, 12:52:53 AM
Bruce_TPU
Good evening ladies and gentlemen.
I have closed out my old thread with a list of Tesla patents, with years, and patent numbers.  And a quick way to look them up at our beckon call.
Earlier today, a new poster PM'd me with some thoughts and links.  While studying out one particular avenue of conversation, I hit upon something someone else that had been mentioned to me in private some time ago, but I did not take the time to research it.
This first post will be to explain my reasoning for what I think and why I think it.  After that I want to devote this thread to "real world" how to do what I propose.  And then to have some skilled in the art to assist with experimention in this regard.
This thread will also be devoted "strictly" to research of what I will present this evening, to "figure" out how to achieve it.  Many of you have other theories and ideas, even some which I have thought and worked through.
For those who wish to disagree, please do so in the "debate" thread and have respect for those of us working.  This is for "practical" how to.  I feel I am finished with more theory.  I understand in my mind what I understand, and now it is time to bring it to fruition.  I do not have the needed skills to do this by myself.  It will have to be a group effort.
Below is a consise list of what I believe needs to be in the TPU.  As well as needed experiment to either confirm or deny.  To see the theory behind these ideas, please refer to my old thread for theory.  Thank you for your time and assistance.
The Study of Practical Mechanics for a Working TPU
A.  Circuit Potential
1.  Must have a rotational field
I now believe I know how this was achieved in the TPU.  And I believe I have found evidence to support it.  This also fits in directly with the 7.3 Hz.  But before I start you must understand the "Egg of Columbus".  This was not covered in my old thread, but in an accidental fashion when talking about ELF in the toroid.
"Tesla's Egg of Columbus"
http://en.wikipedia.org/wiki/Egg_of_Columbus
From the article:
World's Columbian Exposition, demonstrated a device he constructed known as the "Egg of Columbus". It was used to demonstrate and explain the principles of the rotating magnetic field model and the induction motor. Tesla's Egg of Columbus performed the feat of Columbus with a copper egg in a rotating magnetic field. The egg spins on its major axis, standing on end due to gyroscopic action.
Tesla's device used a toroidal iron core stator on which four coils were wound. The device was powered by a two-phase alternating current source (such as a variable speed alternator) to create the rotating magnetic field. A three-phase alternator would work just as well, if not better. The device operated on 25 to 300 hertz current. The ideal operating frequency was described as being between 35 to 40 hertz.
I now believe (near to a certainty) that SM inverted DC to AC at 7.23 Hz.  He then used the four coils around his toroid to setup a rotating magnetic field, using these "reproduced" stationary waves.  Just as Tesla before him did with his toroid.  Tesla used AC ELF as does SM to produce this rotating field.  (Please do not be confused.  We are not talking yet about the high frequencies within the collectors.)
SM said:
"By the way, have you seen the video of the compass turning violently in the center of the unit while in operation? Notice that when I first turn the unit on that the compass starts to spin very slowly. it speeds up faster and faster until it just stops. When it stops the unit is always operating at about it's design maximum.
Now, please listen to this description and see if it sounds familiar:
http://dspace.lib.utexas.edu/bitstream/2152/340/1/nadisf022.pdf
"At the Westinghouse exhibit in the Palace of Electricity, Tesla gave
lectures, presented his ?Egg of Columbus,? which spun and then stood on end as
it responded to a polyphase current like that of his induction motor
Great article on this generator/motor here:
http://home.earthlink.net/~drestinblack/generator.htm
SM's open Tpu also has these four "control" coils providing the rotating magnetic field.
The ELF STATIONARY WAVES are "reproduced" but only in the sense that there is a huge magnetic wave that can be "tapped" into between 7 Hz and 8 Hz.  Tesla's toroid needed iron because of the Hz he was using did not quite "Tap" in that wave.  Remember Marco's video?
In his Colorado Springs Notes, Tesla noted that these
stationary waves "... can be produced with an oscillator," and added in
parenthesis, "This is of immense importance."
So in conclusion of this segment:  The Rotational Magnetic Field is Produced by ELF Alternating Current at 7.3 Hz being input into the FOUR controls around the TPU.  A circuit will be needed to accomplish this.  THIS will produce the rotating STATIONARY waves for the device, on top of the frequencies within the collectors and RESULT IN the phenomenon of magnetic collection.
This is the circuit potential!
High Frequencies within the collectors
2.  There must be three frequencies within the space of the collectors coil circumference.  These three collectors will be tuned to resonance of the high frequencies within them.
When the 7.3 Hz rotating magnetic field hits the rotating magnetic fields setup by the frequencies, the AC signal within the collectors gives us the "AC signal" at the end, but it is through this "VIRTUAL" induction generator that gives us our DC usable power.
I believe the output will also be through induction.  (Experimentation will tell)  This would explain the control wire wrapped around each individual collector, and then the three of them are wired in series, or parallel or both.  SM is a student of Tesla and rediscovered HOW it was accomplished by Tesla.
The controller will need to put out a signal that looks, acts and feels like that of a tube amp.  This is for the frequencies within the collectors.  The frequencies that were given to us are the correct ones to produce power, but only in interaction with a rotating ELF magnetic field.
If the signals in the collectors, are identical, opposing, slightly out of phase, I would experiment this way AFTER the ELF rotational field is in place.  This is the only way to see OU and real power.
Doing the above, we will see vibrations at 7.3 Hz (I already have at 60 Hz).  We will see an AC signal with a DC output.  We will see all the SM clues in play, nothing left out.  I would use a mobius on all ends of the collectors as well.  Experiments will see.
This thread is dedicated to hard working experimenters who have the vision to assist in this endeavour.  I believe this will move our ECD to a TPU.  NOW IS the time to build these pieces and put them together.
With the utmost respect for all those who have spent so long on this project, I dedicate this work you all of you!  I will break the work down, in the future to catagories for all of those who wish to help.  I will make post number 2 of page 1 our build page.  Theory time is over, now we build.
Thank you for your time and may God bless our endeavours,
Bruce
Bruce_TPU
This page is reserved as the future "Build Page"
Thank You!
Bruce_TPU
Hello All,
Yes it is true that "Tesla's device used a toroidal IRON core stator on which four coils were wound."
But you are forgetting the most important part.  He was using 25 Hz or more for his rotating field of stationary waves, not 7.3, close to the shumann's.  Remember Marco's dancing magnets?   SM had a strong enough magnetic field to negate the additon or need for an iron core.
It is an induction generator with a "virtual" rotor.  That works because of the "earth magnetic field".  It is because of these rotating fields that DC is created.
The four "coils" are four AC electromagnet with 7.3 Hz  in them and timed to cause rotation.  It is not an accident that SM talks about the compass that spins and stops when the TPU reaches it's potential.  Neither is it coincidence that Tesla's egg spins until it reached potential and then stopped standing on end.
There was no way the open TPU had enough wire for any sort of "antenna".  We know the TPU vibrated at 7.3 Hz because SM said so in the video.
My very first experiment with the TPU was too wrap the toroid with control wire as an electromagnet and to use standard AC 60 Hz through it.  I had the thing vibrating and when I put two frequencies into it, they felt like little marbles.  All of this is posted on my thread, early on, back when everyone thought I was crazy for thinking that three signals should be put in.
I hope that this helps to convince you.  The Egg of columbus showed me WHY SM used AC and why close to the shumanns.  It also explains perfectly the above clues as well as why there are four coils on the open TPU.
As many of you know I have strongly believed from many clues there was AC in the TPU.  Could now SM have fed it with DC square waves, three frequencies, this gives you AC and fed this into the controls for the four coils to produce the rotating ELF field?  Of course, or he could have run DC square wave into the collectors and inverted AC to the four coils for the rotational field.  Either way, it seems, like it would work.
So in summery:
1.  The 7.3 Hz goes into the four control coils wrapped around the Toroid in four places.  These become powerful AC electromagnets, tapped in to the huge magnetic wave found between 7 Hz and 8 Hz.
2.  We then spin this field over the Toroid with the three high frequencies within the collectors.  The output is through the control wire wrapped all around each individual collectors.  This would give us three output / three collectors.  These can then be wired in series, parallel or both.
Some would already dismiss without an experiment.  Me thinks that hasty.  ;)
Highest regards,
Bruce
eldarion
Quote from: btentzer on July 05, 2007, 10:53:15 AM
Sounds interesting enough that I might try to build one.  The hardest part (and ties into SM's vacuum tube / solid state instability / crystal clear stereo comments) would seem to be building a powerful high-current linear 7.8Hz amplifier that does not produce distortion.
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Bruce_TPU
Quote from: eldarion on July 05, 2007, 03:14:11 PM
Hi Eldarion,
I am not interested in putting 7.3 Hz into the collectors.  The way the ECD has the three HIGH frequencies in the collector is correct.
I am talking about having four (4) electro magnets spaced around the Toroid, each with AC 7.3 Hz.  I have the parts from marco to get AC 7.3 Hz, but the difficult part will be "syncing" the four coils.  As you know an AC electro magnet, reverses poles with each oscillation.  So all four must be synced to give a "full rotation".  This will give us a "virtual" magnetic motor of 438 RPM's.  And only possible because of the earth's magnetic field and the "huge wave" tapped into between 7 Hz and 8 Hz.
I would appreciate any and all help that you can offer this endeavor.  Thank you.
@All
Please remember that this is not a "instead of" what has been done with the ECD.  Rather this is an "addition too".    It will be the rotating magnetic field (egg of Columbus) in the AC electro magnets, plus the three frequencies, primary, harmonic, intermodulation within the collectors.  And then two or three more things in addition to that, that has been discussed on my thread.
High Regards,
Bruce
