0 Members and 44 Guests are viewing this topic.
ltseung888
Quote from: Cloxxki on August 06, 2009, 02:59:46 AM
Lawrence, is it possible to make a mechanically driven lead-out machine?
I'm envisioning an inpout drive shaft, wound would a string, from which a weigh is hung. The output shaft as observer have been able to touch, would be lifting a greater weight, at a greater rate.
Taking motors and batteries out of the equasion should help you gain the support you seek.
Thanks,
The Wang Shenhe electricity generator is an example of a machine with no batteries.  Do a google search on Wang Shenhe.
utilitarian
Quote from: ltseung888 on August 06, 2009, 09:43:10 AM
On a whim, I just did.  Everything I found, and there was not much, was written by you.  And here is one interesting find:
http://hk.dir.groups.yahoo.com/group/hkinventorgroup/message/458
What is this, some kind of Nigerian scam?
chrisC
Quote from: utilitarian on August 06, 2009, 11:17:24 AM
@utilitarian
If you can believe the $200M deposit, I think the Nigerian scams are more believable. But then Lawrence also believes in his UFO's circling between his ears!
cheers
chrisC
ltseung888
Question from Dr. James Wong
If I do not want to double the diameter of the wheel, can I use two wheels instead?
If we focus on the distance a magnet can move before the next pulse, we find that with greater distance to move, the chance of completing the lead-out process will be much higher.
Furthermore, the torque (force x leverrr arm) is doubled.  This means the ability to rotate the wheel faster is increased. ***changed***
We cannot always compensate with higher revolution speed.  This is a common problem with “systems requiring tuning”.
Thus a larger wheel will have a much better chance of achieving overunity.  Most inventors who do not understand the theory would go for small prototypes because of convenience.  Failure is inevitable.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
Cloxxki
Quote from: ltseung888 on August 07, 2009, 01:26:08 AM
If we focus on the distance a magnet can move before the next pulse, we find that the wheel with double the diameter will have 2 x 3.1416 or more than 6 times the distance to move.
With greater distance to move, the chance of completing the lead-out process will be much higher.
Lawrence Tseung
Director
2*pi the distance to move, for a wheel that it only twice the diameter?
Are you speaking about a property other than the circumference of the wheel?
