ltseung888
Question:
If you are so sure that the 225HP Pulse Motor works, should you build a model of the same size?
The larger the diameter, the easier it is to achieve and demonstrate overunity.  If you use 24V batteries and 1 meter diameter wheel with 16 magnets, the effect will easily exceed 2HP output.
Devil
Quote from: ltseung888 on August 08, 2009, 06:39:33 PM
Question:
Tseung, you finally found the main reason why some of the earlier attempts by your friends and other inventors failed.  The experimenters always prefer to build smaller models.  They are easier to handle and the material costs are less.
None of them have seen the 225 HP Pulse Motor and in the back of their minds was the question â€" if it really works, why was it not marketed?  They took the attitude that they were doing you a favor.  You were not paying them full salaries.
Now the small model has shown promise â€" go for the full model.  Once you have completed tests on the single slice, try the multiple slice approach.  The 1 meter wheel with 16 magnets is within the engineering capability of many Universities and machine shops.  Do not let others tell you otherwise.  You are the expert.  They may have the money and resources.  Do not lower the technical vigor and accept unnecessary compromises.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
chrisC
Quote from: Devil on August 09, 2009, 03:18:02 PM
Blah, blab blah blah......
cheers
chrisC
ltseung888
Construction of large diameter rotor.
The Lee-Tseung Lead-Out theory predicts better performance with larger diameter wheel,
A possibble arrangement is shown.
chrisC
Quote from: ltseung888 on August 13, 2009, 07:44:46 PM
What's happening? All quiet on the Eastern front?
Old Tseung, is your UFO ready yet?
cheers
chrisC
