ltseung888
Quote from: teslaalset on November 24, 2009, 05:06:17 PM
Some of the data gives at least some useful information.
So, what you are saying is, the load was basically a battery that was recharged.
*** No load at all.  It turned out some of the connector and wires acted as unintended load.
A battery likely gives some strange current wave shapes indeed in this case. No reasoning for the different frequency though. So, something must be wrong indeed.
*** When we use the recharging of battery as load, we got the shape you displayed.  Good job.
I would expect two current peaks that would occur at the timing of the top of each sinus half of the output voltage (so, a double peak when a magnet passes a receiving coil and therefore double the amount of Hz instead of half the amount of Hz), under the condition that the peak voltage is higher than the battery voltage.
More on the Battery Recharging.
1.   We first used the rundown 12V battery.  Its voltage reading was 6.2V.  When we put it as load to be recharged, there was no reading on the AMP meter but there was a 30 volt reading on the Volt meter.  When we switched the A to mA, there was s small ripple.
2.   Apparently, the current was too small to be measured in the A range.  The Rundown 12V Battery was acting as very large resistance.
3.   We then put a slightly rundown 6V battery as load.  The fuse in the meter in the mA range blew.  We switched back to the A range.  The current reading was over 2 Amps.  The rundown 6V battery was being recharged.
One suggestion was to use two 6 volt batteries as INPUT.  We can recharge one 6V battery at a time.  When the two 6V batteries are fully charged, we switch them as the INPUT batteries.  This suggestion is being investigated.  We need to find out if there were anything strange with such charged batteries.  The conclusive result should be out within a few weeks.  (We have to interrupt the experiment because we need the prototype for the Dec 3-5 show.)
Cap-Z-ro
*still recovering from Bill's earlier groaner*
Or maybe its because Santa always 'goes off' in his sleigh' ?
Regards...
Paul-R
Quote from: ltseung888 on November 24, 2009, 11:44:05 PM
Are they being conditioned? (in the style of Bedini)
teslaalset
Quote from: Paul-R on November 25, 2009, 10:32:02 AM
My personal opinion: No, conditioning according to Bedini is caused collecting BEMF pulses of several hundreds of volts. Lawrence doesn't use BEMF collecting but separate coils for charging.
Paul-R
Quote from: teslaalset on November 25, 2009, 10:35:50 AM
My personal opinion: No, conditioning according to Bedini is caused by BEMF pulse collecting. Lawrence doesn't use BEMF collecting but separate coils for charging.
But if a charged coil discharges, there will be BEMF to be had. It
shouldn't be wasted.
***Waste not, want not. ***
