The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
ltseung888
Email to zero.amp.tech
charlotte@worldviewopinion.com
zero.amp.tech@hotmail.com
Dear Sirs,
I read your invention with interest.  You may like to know the source of energy of your invention.  It is the Lead-Out-Energy via pulse force (or flux change) on electron motion.
The details can be found in:
http://hk.geocities.com/winghang20022002/Presentation.htm
An inventor from China, Mr. Wang Shenhe (or Wang Shum Ho) also had an invention that has COP equal to infinite.  (No input required).  The details are in:
http://www.energyfromair.com/beijing/wang3a.htm  A rotating prototype can be seen at http://www.dsk.cn.
I shall be glad to share any information for the benefit of mankind.
Lawrence Tseung
Director, Help Seedlings Innovate Foundation Limited
Unfortunately that link doesn't work for me. It just loops at the "timezone" thing. Why does a website need to know my timezone? That's never happened before.
But nevertheless, I somehow doubt that this person has achieved what is being claimed.
And the statement that "An inventor from China, Mr. Wang Shenhe (or Wang Shum Ho) also had an invention that has COP equal to infinite.  (No input required) " is a bald-faced lie.
Posted in July:
(begin quote from http://www.worldviewopinion.com/blog/_archives/2008/7/28/3813911.html)
"What does power this engine? Electricity, but no lithium ion battery, so no recharging. The inventor, Peter Sumaruck, says his Zero-Amp Tech system can run AC motors for almost free. The only fuel cost is for ignition powered by a minute amount of gasoline. For a year of heavy use, a driver will need only 6 to 9 gallons of gas from the small tank onboard. Because there are no large natural gas or diesel fuel tanks on board, accident-caused explosions will be negligible, if nonexistent, making this an extremely safe vehicle. After ignition, his new engine design just keeps running at 100% efficiency until it’s turned off. The engine does not get hot.
Sumaruck takes a new or existing truck - an 18 wheel for example - made to order, with no engine. He installs a replacement turbine drive system (on the same principles as Hoover Dam). The sealed 100 gallon tank using salt water (or any water) is under very high pressure; the turbine is constructed of aluminum alloy and copper clad, and powered by a 10 to 500 horsepower 3 phase AC motor.
The standard transmission is kept in place, as well as the alternator and on board battery to power lights and air conditioner. This Zero-Amp Tech adapted truck can travel at the same speeds reached by diesel-powered trucks. In fact, Sumaruck can modify this system even further for extremely long hauls and very heavy loads like those roaring down long stretches of nowhere across the Australian Outback. Zero-Amp Technology can adapt this operating system to other large vehicles: buses, garbage trucks, cement mixers - the list goes on.
Very little maintenance is needed because nothing is stressed - three fan belts, changed maybe every 200,000 miles. Sumaruck uses heavy duty parts - if 2 in. wide is common place, he uses a 4 inch wide belt.
Some of this may sound straightforward, even simple. Sumaruck says yes, but “the complicated part is in the computer hard drive.” That’s where the genius work takes place. Through 2 small 44 gage wires, ignition comes in at .019 mA (milliamps), and comes out at 150 amps, non-fluctuating, precisely 60 cycles. This is where Peter Sumaruck disproves the First Law of Thermodynamics, which states that you never get more energy out than you put in. Even if there were not all these thousand of applications for this new technology, the fact alone that this bulwark law of physics has been disproved is reason enough for amazement. We all need to learn to recognize genius."
(end quote)
Do you believe it?
I certainly do not.
Another unbelievable gem from PESwiki:
"Zero-Amp Technology was tested by the United States Army from 2003 to 2004 - units operated perfectly from day one. "
Uh-huh. I guess that's why the Army is powering all its tanks and trucks with Zero-Amp Technology.
Or maybe that's why there isn't any solid information about this technology--it's being suppressed by the Army.
Go on, pull  the other one.
Several websites repeat the claim that Sumaruck has "over 14 patents". Not over 15? Just how many patents does Sumaruck have?
Well, I searched the USPTO patent and patent application databases for inventors or assignees named "Sumaruck" and found...zilch.
Maybe his patents were issued before 1976 (in which case he was barely in his twenties and still very busy as a Navy SEAL, according to his claims) or perhaps they are not US patents.
If anyone can come up with a patent or application for a patent issued to or applied for by Peter Sumaruck, please let me know.
spinner
Quote from: TinselKoala on November 27, 2008, 09:59:35 AM
A CoP equal to infinity?  :D     There goes Thermaldynamics Laws... Unity screwed by Infinity.
What about the guy, who said recently - something like "the input to the "xyz device" is zero, and the output is zero, too... Therefore, the device is 100% efficient"....  ;D
No doubt, if one disconnects the power, most of el. devices goes to a "Zero Amp Power" mode... Pull the plug out and... Voila...
....Through 2 small 44 gage wires, ignition comes in at .019 mA (milliamps), and comes out at 150 amps, non-fluctuating, precisely 60 cycles. This is where Peter Sumaruck disproves the First Law of Thermodynamics, which states that you never get more energy out than you put in. Even if there were not all these thousand of applications for this new technology, the fact alone that this bulwark law of physics has been disproved is reason enough for amazement. We all need to learn to recognize genius."
;D ;D ;D
@Hans
Your cartoons are simply the best!
Thanks!
"Ex nihilo nihil"
