The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
Can't you just put coils on both sides with your plastic stopper thing and put some kind of switching mechanism which can even be a reed switch. That way the thing will oscillate at its own mechanical resonant frequency depending on internal tube friction, its mass and the field strength.
ltseung888
This is the third experiment.  Note that it combines both magnetic attraction and repulsion â€" with the same current to a continued coil.
The experimental configurations are given in detail for the benefit of the teams in Singapore and Taiwan.  They can replicate the experiments without coming to Hong Kong.  Teams from other parts of the World are also welcome.
We expect this configuration will produce the greatest jumping height amongst the mentioned three experiments.
The Tong Po Chi device in the youtube video basically used this configuration but not much tuning was done.  The goal at that time was just to produce the effect.
We expect the tuned device will achieve a jumping height of more than 30 cm.  If we join two of these together, the jumping height from one Pulse Current should still send the combined device to a height of more than 10 cm.  This will be sufficient for us to carry on with the next definitive experiment.
ltseung888
This is the fourth experiment.  Note that it uses the best configuration from the previous three experiments as the basic unit.  It then combines two of them to illustrate the capability of jumping in mid-air.
The mechanical Pogo Device cannot do that.
In the double configuration, the current to M is started first.  That will send both M and N to mid-air.  Current to N is then started.  There should be an additional increase in height.  This is what I call a ‘definitive’ experiment.
We have to wait for the hardware stores to open on Feb 2, 2009 for additional parts.  In Hong Kong, many hardware stores open all year except the week of the Chinese New Year.  The experiment is worth the wait.
If the double configuration can jump higher in mid-air, the theory that we can produce an unbalanced force for propulsion purposes within a closed system is totally validated.  The remaining tasks will be tuning and programming so that the repeated pulses could sustain the continued upward force against gravity.  The man-made Flying Saucer will be reality.
hansvonlieven
Quote from: ltseung888 on January 29, 2009, 09:00:17 PM
G'day Lawrence,
Of course the mechanical pogo stick cannot do this, neither can your contraption.
Hans von Lieven
ltseung888
This is the fifth Experiment.  It has special significance because it will have immediate application even if the Flying Saucer is not up in mid-air yet.
A consultant with the Chinese Railway system remarked: “If by passing current, you can reduce the weight of a train, we shall be interested.  We already know that we can use magnetic repulsion to effectively raise the train.  But that requires much special equipment at the rail etc.  Your device may be an add-on to the train.”
The experiment is just applying the result of the previous experiments.  When a permanent magnet passes at high speed through a Coil with attraction, that high speed will be increased due to magnetic attraction just before reaching the Coil.  However, at the middle of the Coil, the permanent magnet will quickly slow down due to the attraction.  The rapid change in momentum provides an upward force via the Coil to the entire object.
If the magnetic balls rotate at high speed, there will be many pulses of upward force per second.  This may be demonstrated as a reduction in weight of the total object.
For the purpose of this experiment, any mechanism to supply and maintain the rotational speed of the magnetic balls is acceptable.
Building the WBLT is a very scientific process.  It is not as easy as ordering a hamburger at Wendy's. ;)
