The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
ltseung888
Dear All,
Solving the Engineering problem of the Large Wheel.
The major engineering problem with the large wheel is the need to keep a 1-2mm distance between the stationary coils and the fast rotating magnets.  The engineering problem is relatively simple when the diameter of the rotor is 15cm as in the existing prototype.
However, if the diameter of the wheel is more than 130cm as in the proposed large wheel, the engineering problem becomes enormous.  The centripetal force tends to pull the magnets out from the rotor.  The blunt shape tends to have high air resistance.  The slightest vibration or imperfect engineering would allow the actual collision between the magnets and coils.  That results in the destruction of the prototype.
One technique as adopted by the 225 HP Pulse Motor design is two concentric cylinders.  The outer one is stationary with the coils attached.  The inner one is rotating with the permanent magnets attached.  There will be friction problems to overcome with such a design.  However, the possible fatal collision problem is avoided.
Are there any other brilliant suggestions or solutions?
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
Paul-R
Quote from: ltseung888 on September 02, 2009, 10:54:02 PM
...the blunt shape tends to have high air resistance....
Could you mount the system in an enclosure, and pump the air out of it to reduce air resistance? You might get heating issues.
utilitarian
Quote from: Paul-R on September 03, 2009, 08:55:27 AM
I believe this option is out, since it would require some expensive equipment.  Maybe Lawrence could borrow the money from his friend Wang, who apparently received a $200 million deposit in his bank account, probably from a relative of an African prince who just died.
But seriously, does this make sense to you, Paul?  Lawrence's close friend and business associate receives $200 million for his invention, but Lawrence is slapping something together with nails and particle board, trying to get a prototype to work, documenting his work by discussing it with his multiple personas on an obscure Internet forum.  Shouldn't they be past this stage by now?
Paul-R
Quote from: utilitarian on September 03, 2009, 10:32:13 AM
Yes, it does.
But then, I have studied Lee & Yang (et alia), and I suspect that you haven't.
As for the sums you quote, if you talk to the right people, it all makes perfect sense.
utilitarian
Quote from: Paul-R on September 04, 2009, 11:03:40 AM
Yes, it does.
............................................________
..............?.....__.........................................:`.........../
............./__.(.....“~-,_..............................,:`........../
.........../(_....”~,_........“~,_....................,:`........_/
..........{.._$;_......”=,_.......“-,_.......,.-~-,},.~”;/....}
...........((.....*~_.......”=-._......“;,,./`..../”............../
...,,,___.`~,......“~.,....................`.....}............../
............(....`=-,,.......`........................(......;_,,-”
.............`~.*-,.....................................|,./.....,__
,,_..........}.>-._...................................|..............`=~-,
.....`=~-,__......`,.................................
................................`:,,...........................`..............__
........................................_..........._,-%.......`
