The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
ltseung888
Quote from: tagor on August 12, 2007, 02:28:42 AM
Quote from: ltseung888 on August 11, 2007, 04:51:45 PM
Interesting Toy ? Leads Out Gravitational Energy?
http://youtube.com/watch?v=4uLPMGrMohc
sorry but this thing does not exist any more
so it can not be a proof
can you replicate it ?
I was involved in the Sun et al experiments with the simple gravity motor based on the following:
http://theverylastpageoftheinternet.com/newclaims/GravityMotor/gravity_motor.htm
Sun et al produced over 20 variations.  I have 3 in my house.  The initial wheel stopped rotating after 1 minute.  (The hammers did not hit the right spot - the rim).  We then improved via the following:
(1) Let the hammers hit the rim.
(2) Change the weight of the hammers.
(3) Vary the number and position of the hammers.
(4) Use falling steel balls inside tubes to replace the hammers.
(5) Use falling powder inside tubes to replace the hammers.
Ms. Forever Yuen helped me to increase the rotation time for one of the variations in my house to 20 minutes.  Sun et al improved it further with magnets.  With an arrangement similar to the Minato Wheel - with hand movement controlling the angle and position of the magnets, he could get the wheel to rotate forever.  (That was regarded as cheating as energy can be supplied by the hand movement.)
Sun et al then placed the wheel in the vertical position and could achieve a rotational time of 30 minutes.  (A big improvement compared with the 1 minute attempt.)  As a comparison, the wheel rotating by itself without the magnetic interaction would stop after 10-13 minutes.
We learned the very difficult task of resonance tuning.  A seemingly insignificant change could affect the result considerably.  For example, we swapped two magnets brought from the same shop.  The improvement jumped over 30%.  (At this time, we did not have equipment to check the strength of the individual magnets.)
The "wood hitting wheel" is similar in concept to the above simple gravity wheel.  It used pulsed rotation. We believe much tuning is required to get the best result.  I do not do prototypes myself.  Sun et al may do it at their spare time in their machine shop.  Sun et al are working on a primitive form of the 225 HP Pulse Motor at present.
We may have some surprises as Sun et al are planning to produce "platform toys".
Unlike many of you, I am 100% confident in my Lee-Tseung Theory.  Lee and I played with at least 4 working Cosmic Energy Machine prototypes - by other inventors such as Wang, Ting, Liang and Chao.
Lawrence Tseung
Experience with working prototypes Leads Out supreme confidence.
ltseung888
Look at the following information related to the Chas Campbell Machine.
http://video.google.com.au/videoplay?docid=-5520200869600922360
http://www.panacea-bocaf.org/ChasCampbell.htm
The Chas Campbell Machine Leads Out gravitational energy similar to the Electricity Magnifier at Tsing Hua University.  See slide 16 of
http://www.energyfromair.com/beijing/taiwan2a.htm
The Tsing Hua University Electrcitiy Magnifier can magnifier input 30 times via three rotating cylinder.  The Chas Campbell Machine claims to magnify input 10 times at present.  Campbell uses flywheels with weight concentrated at the rim.  He could increase the efficiency by using cylinders.
I believe members of this forum are in touch with him in Australia.  It is another application of the Lee-Tseung Lead Out theory.  (We used it on the Tsing Hua device.)
Lawrence Tseung
Chas Campbell device Leads Out another confirmation of the Lee-Tseung Theory.
Paul-R
Your ideas and inventions are very intriguing, but it is impossible
to get proper copies of your patents in English. Your patent
number 99126283.2 was not found by the Chinese web site.
Please can you provide an English version of the description
and claims, along with drawings.
I would urge you to file with the EPO as well if you want to
make the most of the system.
Paul.
shruggedatlas
Quote from: ltseung888 on August 12, 2007, 06:32:44 AM
Mr. Tseung, is there any perpetual motion machine that you are actually skeptical of?  You seem to accept any old crap posted on the Internet as the real thing.  No one will take you seriously, especially in this field, which is full of fraudsters, if you continue to do this.  Having a 500 post discussion with your alter egos on the Steorn forum does not help either.
ltseung888
Quote from: Paul-R on August 12, 2007, 10:10:48 AM
Paul.
I shall first put the official information in Chinese.  The website is:
http://search.sipo.gov.cn/sipo/zljs/hyjs-yx-new.jsp?recid=CN99126283.2&leixin=fmzl&title=磁èÆ'½å‘电æÅ"º&ipc=H02N11/00
The inventor is: 宋添发
The abstract is:
æÅ"¬å‘明提供ä¸â,¬Ã§Â§ÂÃ¥Ë†Â©Ã§â€Â¨Ã¦Â°Â¸Ã§Â£ÂÃ¤Â½â€œÃ¤Â½Å"为èÆ'½æºçš„磁èÆ'½å‘电æÅ"ºï¼Å'Ã¥Å'…括主轴ãâ,¬ÂÃ¦ÂÂ¢Ã¥Ââ€˜Ã¥â,,¢Â¨Ã£â,¬ÂÃ¦Å"ºå£³å’Å'定子转子组ï¼Å'换向åâ,,¢Â¨Ã¤Â½ÂÃ¤ÂºÅ½Ã¤Â¸Â»Ã¨Â½Â´Ã§Å¡â€žÃ¤Â¸â,¬Ã§Â«Â¯Ã¯Â¼Å'其宯'éÆ'¨åˆ†ä½äºŽä¸»è½´çš„另ä¸â,¬Ã§Â«Â¯Ã¯Â¼Å'æÅ"ºå£³å†…设æÅ"‰è‡³å°‘两层定子转子组ï¼Å'每层定子转子组åÅ'…括æÅ"ºå£³å†…层å¥â€"ãâ,¬ÂÃ©Å¡â€Ã¥Â±â€šÃ¦ÂÂ¿Ã£â,¬ÂÃ¥Â®Å¡Ã¥Â­ÂÃ£â,¬ÂÃ¨Â½Â¬Ã¥Â­ÂÃ£â,¬ÂÃ¨Â½Â¬Ã¥Â­ÂÃ§Â£ÂÃ¥Ââ€"å’Å'主轴定位å¥â€"ï¼Å'定子上绕æÅ"‰ä¸åÅ'用éâ,¬â€Ã§Å¡â€žÃ§ÂºÂ¿Ã¥Å"ˆç»•组ï¼Å'转子固定åÅ"¨ä¸»è½´ä¸Šï¼Å'其上设置多个转子磁åâ€"ãâ,¬â€šÃ¨â€¹Â¥Ã¥Å"¨ä¸»è½´ä¸Šå¢žåŠ è¾“å‡ºç«¯å¹¶æ”¹å˜ç»“æž„è®¾è®¡ï¼Å'æÅ"¬è£…置可变成磁èÆ'½å‘动æÅ"ºãâ,¬â€š
You can get professional patent translators to do the proper patent translation.  I shall only do a layman/scientist version that cannot be used in Law Courts.
