The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
hansvonlieven
Quote from: ltseung888 on October 22, 2007, 01:04:54 AM
Quote from: foreverComments on balanced rotations
1.The best way of leading energy out from a pendulum is to apply a pull force perpendicular to the direction of the moving arc.
2.Intuitively, I believe the best way to lead out energy from a rotating cylinder is also to provide forces perpendicular to the direction of movement.
3.This means applying the force tangentially.
What do you think about my intuition?
Dear Forever,
I love your intuition.  I am going to open your posts for comments from all.
More details are in http://forum.go-here.nl/viewtopic.php?p=344#344.
Your intuition simplifies development for many Over Unity Inventors.  There is no more need for guessing.  Just apply tangential force to rotations.
Lawrence Tseung
What utter rot,
I don't know who MS. Forever Yuen is, presumably just an other one of Lawrence's alter egos. No Lawrence, don't post another picture anyone can post a picture and say it is real only because it shows some attractive Chinese lady.
Whatever the story, real or not, neither of you has an elementary grasp of physics.
Every engineer knows, and I don't mean because they read it in a book but because they WORK with such things every day, that if you apply a force perpendicular to the natural movement of a body, its movement becomes erratic and it starts losing energy.
This is true for wheels, pendula and anything else that moves.
Neither of you understand the basics of motion, I suggest you go back to school and learn something about physics before you publish stuff like this.
Hans von Lieven
ltseung888
Quote from: hansvonlieven on October 22, 2007, 02:58:17 AM
Hans von Lieven
Dear Hans,
I believe that every Engineer also knows something about Newton's Laws of Motion.  An object traveling in a straight line with velocity v will continue traveling with velocity v if there were no other forces acting on it.
In Circular Motion, there will be centripetal force acting perpendicular to direction of motion. Even though there is a force, no work is done because there is no displacement in the direction of the force.
For the Lee-Tseung theory to be applicable, we need the Pulse (periodic Push or Pull) to do work to Lead Out Gravitational or Electron Motion Energy.  When we apply it to the circular motion of a pendulum or a rotating wheel, the wheel has to accelerate and decelerate.  This is the phenomenon of ?if you apply a force perpendicular to the natural movement of a body, its movement becomes erratic and it starts losing energy.?  The Lee-Tseung Pull or Push is to try to spin the wheel faster (accelerate) and let the Output Energy to slow down the wheel (decelerate).
Most Engineers were trained to try to achieve balanced rotation. For example, to balance a wheel, they put small weights at the rim to ensure balance and constant velocity rotation.  This is totally different from the Lee-Tseung Requirement of ?Letting the periodic Pull or Push (Pulse)? to do work to Lead Out Gravitational Energy.
What you regard as Engineering Stupidity and Nonsense is vital to the design of the Cosmic Energy Machines.  The Wang Device is the clearest example of unbalanced rotation.  Details in http://www.energyfromair.com/beijing/wang3a.htm.
hansvonlieven
You are dreaming Lawrence'
When you apply a pulse (any pulse) perpendicular to motion you slow the body in motion down. Brakes operate in such a way. There is no lead out energy in applying a brake.
Hans von Lieven
gaby de wilde
It's easy to power a device with gravity.
Why haven't you figured it out jet Hans?
blog  | papers | tech | inventors  | video
gaby de wilde
Quote from: ltseung888 on October 23, 2007, 08:39:42 PM
It's cute but it's WRONG!!
An object can only travel if there are other bodies.
If there is nothing else then there is no motion.
A universe demands 2 objects to have the motion phenomenon.
And objects erect gravitational fields.
1+1=2
So there is no linear motion there where there are no other forces.
Which means an object traveling over a curved line will go WAY BEYOND velocity V
End of story!
My space ship gets there 1000 years before yours does. ROFL!!!
