The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
ltseung888
Looks like somebody is still confused.
The rest of the story was:
(1) When the water rate was increased, a large column of water accumulated at the bottom.
(2) We just could not pump air+water up.  When someone strong used all his might to step on it, the US$1.00 pump bursted.
(3) I left with the suggestion of using the tested method of one-way valves.
(4) The group informed me later that they used a half horse-power air pump to get the air+water up using the one-way valve method suggested.
(5) They said that they showed it to many others but wanted money to do further research and refinement.  I could buy them dinner but could not support the many thousand dollars of turning that into a product.
(6) I got involved with the more challenging Leading Out gravitational energy directly project.  I decided to give the theory and the proof-of-concept information to the World.
Lawrence Tseung
Theory is important.  Read 643 and 758 to get more education.
hansvonlieven
Quote from: ltseung888 on December 08, 2007, 12:25:50 AM
Hans,
I am going to tell you why you will be paying for the US$10 meal.
The experiment done was as follows:
(I actually took part in this section of this experiment.)
(1)   We purchased a roll of clear plastic tubing that would fit the outlet of the US$1.00 valve.  (Inner diameter = 7 mm) Each roll was 100 meters. (paid for by Tseung)
(2)   We went up to the 34th floor and let the tube down.  We had a strong guy holding the upper end of the tube. (Tseung was NOT the strong guy.)
(3)   At the ground floor, we used the US$1.00 beach pump to pump air only.  We detected that air actually came out from the upper end with a tissue paper. (Tseung and many others did the pumping.  It was a piece of cake.)
(4)   Then we introduced the set up with the lower water tank but no one-way valves in the tube.  Water was introduced/ dripped very slowly.  Water droplets were seen going up the tube.  (The tube was clear plastic.)
(5)   At the top floor, the tissue paper got wet.  Thus we were 100% sure that water did arrived at the top.  We did not care about the flow rate then. (Tseung and others took the lift to go up to check.  Tseung did not need the exercise!)
Water got to the 34th floor.  Have I won the bet yet?  If not, I shall continue the story.
Lawrence Tseung
Winning a bet is easy if you have already done the experiment.
I don't know how you got the tissue paper wet. A little foot pump will NOT propel water 34 floors up, no matter how hard you pump.
You must think we are complete idiots.
I have worked with these systems, I KNOW what they are capable of, and that is just not it.
Next you will tell me you can power an aeroplane with a 1cc model aeroplane motor.
No matter how hard you wish, some things just cannot be done and dreaming up data is not going to help. But just to be awkward, how does a wet tissue on the 34th floor prove your claim that you can get more than enough water up there to power the pump?
As usual you are talking rubbish again.
Hans von Lieven
ltseung888
Dear Hans,
You do not need to get angry.  If you cannot afford the US$10, you can ask your CIA friends to chip in.  I am sure ChrisC would not mind paying double.
You may even ask your management to spend the US$20 to buy the various parts and replicate the experiment.  Wait until you get the wet tissue paper before you buy me dinner.
Once you get the proper set up, may be less than a height of 34 floors - I do not know about the tall buildings in your area.  Hong Kong is full of them.
You can invite your management to have a light shower below the outlet.  Warn them to bring raincoats.
You may be able to win a US$100 meal from them.
Learn the theory.  Energy from Still Air was involved. The Input Energy is the sum of the Pump Energy + Energy from Still Air.
Lawrence Tseung
Giving the CIA management some cold shower should be fun.  It helps to clear their minds and stop invading other nations with false information.
amateur
Dear Lawrence,
The science that you have proven is called evaporation
