Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bruce_TPU
@ Bob
Thank you for the explanation.  We will wind with just the magnetic bias longitudil winding and not the top and bottom winding.  I look forward to hearing how your future experiments go with the top and bottom windings.
I am very curious, of your TPU history.  What in the world gave you that first idea?  All of us had S.M. Videos and pages of clues (though we were clueless! LOL)  What gave you the "spark" of insight to first develop this and to push for OU.  Your answer will make for a good addition to the introduction part of the .PDF
Bruce
@ All
Skycraft Parts & Surplus
Business Hours (E.S.T.)
Mon-Fri: 8:30 - 6:00 p.m.
Saturday: 8:30 - 5:00 p.m.
Sunday: Closed
2245 West Fairbanks Ave.
Winter Park, FL 32789
Tel. (407) 628-5634
Fax (407) 647-4831
Grumpy
Where  in the hell did the 10ns requirement come from?
Bob's freq's are in the low khz range - far above 10ns.
TEsla worked from ns to millseconds with his RE devices.
In short, try everything.
        -Frank Edwards
eldarion
Quote from: MeggerMan on July 27, 2007, 07:39:52 PM
@Eldarion,
I remember you from the EnergyMover on google - MEG project.
Can you get fine frequency increments using your  spartan 3 board, say 0.1Hz?
Rob,
Good to see you here!  I remember many nights trying to get that MEG working, to no avail...hopefully this will work out better! :)
Yes, I can get fine frequency increments with the Spartan--very fine, down to about 10ns of precision, in fact.
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
giantkiller
Quote from: Grumpy on July 27, 2007, 11:29:33 PM
Well call me wrong on this one, if possible.
If one looks at the LMD we see stages, phases and 1 oscillator. Now wrap that in a circle.
In the beginning I stated smack it fast and get out of the way fast. Thats all. The output far exceeds the technology. Technology that Tesla did not have.
I proved secondarily from Otto's design that phase cancellation did the high speed job. Oh well. My testing proved that the coil can do all the work dynamically. The LMD and the stun gun stages all build up potential to the final output.
Could things have gotten that far off the beam? Tangentential metatronics.
So my wrap up is to connect it with diodes across caps to spark gaps, neon bulbs, or neon starters and be done. I will state this again for historical purposes. We are going to end up with stungun circuits reconfigured. Remember SM shorting the leads of the SM15/17? Clock it anyway you want. It is still a stun gun turned back on itself. What is the oscillator speed of a stun gun? 6khz. Close to SMs 5k. And my most famous quote? 'It's sloppy'. But now I am humbled because Dollard stated this in 1988. They didn't even try to tune it.
--giantkiller. http://video.google.com/videoplay?docid=-6461713170757457294
Bob Boyce
Quote from: btentzer on July 27, 2007, 09:20:50 PM
Bruce
While working as an engineer for a govt. subcontractor, I became aware of a problem with a switcher power supply, that under certain temperature and load conditions would go into overunity operation. Sometimes these would fail in a big way and totally destroy the load. Way more damage than the power source to the power supply was capable of delivering. The power supply board used an onboard toroidal inductor, wound with teflon insulated silver plated solid copper wire on Honeywell powdered iron cores. I guess this is what started my interest in this. When I went into business for myself, I had the time to devote to research and experimentation.
My early radiant energy research and experimentation were with attempting replications of Tesla and Moray devices, as well as many others. I found a copy of Dr. Hans A. Niepers's Revolution book, ISBN 3-925188-07-X. In that book there is information about many devices related to the conversion of gravity field energy.
My first foray into a 3 phase device was during experimentation with a g-strain energy absorber as theorized by professor Shinichi Seike. Needless to say, the results were not what I expected when I connected a 3 phase air core toroid to the 3 phase outputs of the g-strain energy absorber board.
I had been doing these experiments at home, and that was where my lightning strike injury occured in 1995. That put an end to my 3 phase research for a number of years. When I did start back into it, I soon tired of the expense of burned out electronics and loads. I went back to the lower powered single phase transformers and stuck with that until I worked out some of the control issues that would to allow me to get back into the 3 phase design in a more controlled manner. I wish I had heard of Steven Mark sooner, would probably have saved me some time ;-)
Like Steven, I learned to have a very healthy respect for this stuff.
Bob
Edit: typo fix
