Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bruce_TPU
@ All
I had written Eldarion about this and feel based on what Bob has just shared, that we do the following.  If anyone puts the controller into the eye of the storm, that a Manual Kill Switch be placed outside, for you to access as Steven Mark told us.  "Remember the Kill switch!"  Also, over voltage, and over heat sensors wired to kill the frequencies and power if tripped must be adhered to.  I would say not to even test any three phase system without this.
Quote from: Bob Boyce on July 28, 2007, 11:03:58 AM
One "trick" that can be used to improve power density a bit at lower frequencies is to go from 3 primaries to 6 primaries, ie 2 phased sets of 3 phase drive coils. I did not do this for the hydroxy gas related cores due to the pulsed mode of operation, but I did experiment with it in the RMF energy cores.
Bob
@ Bob
Would you suggest we start off now with the 3 primaries to learn on, and then the 6 primaries next?  Or should we start with the 6 primaries now.  (when our cores arrive.)
Bruce
Bob Boyce
Quote from: weri812 on July 28, 2007, 12:31:16 PM
hello Bob
like the added coil to your tpu
i am going to make 2 of your tpu using your board  pwm3f-hp.
you said that  you are using 20ga instead of 16ga is this what you recamend
or is that what you are using for the  top and bottom  coil only.
and  we wind ccw on all coils in  usa?
thank you for helping
wer
The PWM3F-HP is fine for running a hydroxy system, if that is the direction you are planning. The 20 guage longitudinal wound windings are not related to hydroxy system operation, so you will not need those for that purpose. The 16 guage secondary winding and the three primaries are all you will need for hydroxy use. You can add the longitudinal winding for future use if you intend to do research along those lines in the future.
Bob
Bob Boyce
Quote from: btentzer on July 28, 2007, 04:14:21 PM
@ Bob
Bruce
Since the primaries are on the outside, the additional primaries can be added later if you decide you want to go that route. One of the replicators has wound all 6 on both of his toroids, but he is only using the one set of 3 of them at this time.
Bob
Edited to add: I forgot to mention, the HexController was designed to drive all 6 coils individually if desired. This was what the Hex in the name referred to.
Motorcoach1
 Bob in the Tesla patents they talk about the AG material being as of equal weight on the secondaries and the primaries, Does this stay true to what we are doing on this coil.  Mike
Bob Boyce
The toroid core bottom face longitudinal winding is done. It wasn't so bad winding it clockwise, just took a little getting used to at first ;-)
Bob
