Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bob Boyce
Quote from: Motorcoach1 on July 28, 2007, 10:13:09 PM
Bob in the Tesla patents they talk about the AG material being as of equal weight on the secondaries and the primaries, Does this stay true to what we are doing on this coil.  Mike
Not on this type of unit.
Bob
Bruce_TPU
Hi Bob,
You sure do some nice winding!  I think that seeing with our eyes, the precision involved, will cause all of us to take our time and to do it correctly.  We need to source some Beeswax as well.  Do you know a supplier for the large block that you showed in your other picture?
Any guesses on what will happen when you fire up the top and bottom windings?  Will they be low voltage or high voltage static bias'?   Or will you try both?
@ All
Tomorrow, I will be starting a new thread that will be locked.  It is the Builders Update and will include each weeks progress update from each builder.  This will act as both a build diary, and resource if you need to know if someone is working on something that perhaps you either need help on, or can be of assistance.  At a later date it will turn into the builders experiments update thread.
Bruce
Bob Boyce
Quote from: btentzer on July 28, 2007, 10:48:20 PM
Hi Bob,
Bruce
Thank you. I do try to make accurate windings, even when they are not so critical as in these longitudinals. The secondary and primaries are always a challenge for me, as I attemp to get a tight wind at the toroid center while keeping each turn spaced the same from one another around the periphery. The primaries are the most critical of course, as the accuracy there directly affects timing.
My beeswax was sourced from eBay. The not-so-local health food store only had tiny 1 ounce blocks for US $1 each, while a seller on eBay had 1 lb blocks for about US $10 each. I had stocked up so have plenty of it.
Those top and bottom windings were not planned for use as bias windings. I wanted to see if adding these would allow for additional output in homopolar fashion without affecting operation. This is why they are both wound CCW from inside to outside when looking down from above.
Bob
Motorcoach1
Bee's wax get this from Home Depot , go to pluming and get tolite bowl seal ring made from Bee's wax ! dada :)        I have a steel ring here so I'm going to practice winding this one. get my skill level in.  and dahh I forgot the tolite bowl ring when I  was at the store. :0
Bruce_TPU
@ Mike
A bright idea.  Though it will read funny on the "build page" when I get it together.  One toilet bowl seal... ;D  I had no idea it was made of Bee's wax!
I have verified it is 100% bee's wax.  I won't ask how you knew that Mike!  LOL   ;D  So we now have a ready, cheap souce at our disposal (no pun intended! Ha!) from any local building supply.
Bruce
