Newman machine with a closed loop selfrunning without batteries or solar panels
Started by hartiberlin, July 26, 2007, 09:40:54 PM
Andre
A baby can move that if he/she was using a long enough lever.   Your hand and arm is not a solid lever, yes then you will need many hands to move it.  Small power apply over a long enough distance can accomplish magic because of simple phenomena of Torque (Nm) = Power (N) x distance (m)
Archimedes:?Give me a lever long enough and I will move the earth?
seekingknowledge
Quote from: hartiberlin on October 27, 2007, 04:25:41 PM
We are looking for a conventional 1HP generator that operates on LOW rpms -- in the 100 rpm range. There may be some windmill-related generators that operate at those speeds.  We would like to find a USA supplier.  If you have any contacts/sources that might sell such a generator, we'd be interested.
Cool but is this to demonstrate power output or to make it a selfrunner like we are all patiently awaiting?
Lakes
If this thing works from voltage and not current, then lets see it run from a capacitor.
H2earth
Joseph Newman's big mistake was in spending the last 10 years re-engineering the device to get rid of the hugh back-EMF spikes, in favor of more mechanical energy.  That he has done this is evident in his 2006 European patent filings and he's said as much in some of the videos.  That 7,800 lb. monstrosity is an albatross that he would do well to abandon in place.
Newman took that approach (designing the backspikes out of the system) after many frustrating years in which the obvious overunity energy output would fry batteries and blow capacitors, and could not be effectively harnessed by conventional approaches, despite the fact that many sources confirmed it to average >COP=8 (800% efficient, output from input).
Joe Newman and Stan Meyer were both too ego driven to ever take notice of one another, even though they were contemporaries on the free energy circuit, travelling around the country at the same time in the 1980s.   The fact is that the original Newman machine puts out the same HF/HV waveform, at the same polarity, as is required by the Meyer Water Fuel Cell as Input.   You send those huge backspikes through the WFC - "a water capacitor that likes to be blown", and it achieves sudden, catastrophic dielectric breakdown of the water, producing copious amounts of hydroxy fuel gas in the process - AND giving off a nice, straight DC power output from the WFC's Electron Extraction Circuit, which will charge batteries just fine.
The Newman device you want is not the modern linear one with all the magnets and the flat radial coils around it, its the older version, with one big magnet rotating in the center of two coils, as in Fig. 6 of his PCT patent, which is now expired and in the public domain.   We have found that there are four obvious improvements to it which should greatly increase its performance (none of which has Newman himself implemented):
1.  NdFeB-50 Supermagnets have been used to improve the performance of all kinds of motors and generators, as detailed in http://consult-g2.com/papers/paper17/paper.html and the next generation of Newman machines should be construcfed with them.
2.  Tinned Copper wire coils were found by Electrodyne Corp. to produce 3x the magnetic field of those wound with conventional copper wire, as per The Manual of Free Energy Devices and Systems by D.A. Kelly
3.  Coils wound as Bifilar have been demonstrated to hold 250,000x the energy of conventional coils of the same wire size and composition in pulsed high voltage applications, as first detailed in the original Tesla coil patent  http://www.freepatentsonline.com/0512340.pdf   This produces much higher backspikes than any Newman machine to date.
4.  A ferric steel 'keeper' has been conclusively shown to concentrate the magnetic flux and increase the performance of motors/dynamos by a factor of three, in the Lindemann video "Electric Motor Secrets".
An enhanced implementation of the original (Fig. 6) Newman machine, which delivered most of its energy in the back EMF spikes, incorporating these improvements is shown below:
It is hoped that this version can serve as a common module for use with both an automotive Water Fuel Cell, and for home power applications as part of a Tesla Switch assembly, known as the Geovoltaic Energy Pump.  http://peswiki.com/index.php/OS:Geovoltaic_Energy_Pump_(GVEP)
The H2earth Institute seeks to trigger the sudden immediate discontinuous adoption of waterfuel technologies for home power and automotive applications, on a mass market basis, within five years.
NerzhDishual
Hi Over Unity.Com sharp minded Fellows!
I'm notably impressed by the H2earth's post.
Sorry for disturbing -I'm not a scientist- but, may I direct you to: http://freenrg.info/TESLA/
And notably to:
http://freenrg.info/TESLA/Nikola_Tesla_Complete_Patents.pdf
and: http://freenrg.info/TESLA/Nikola_Tesla_Us_Patents_Index.pdf
Where you can find an huge (40 Meg) .pdf file which includes (all? = more than 120) US Tesla patents. 500 pages. Check out your printer :).
IMHO: After having read some of this patents I'm now beginning to figure out that he seems telling us a kinda story along with his patents (should I say a 'novel') and that you have to read them all to get the whole picture.Very strange feeling indeed.
Best
Nolite mittere margaritas ante porcos.
