Newman machine with a closed loop selfrunning without batteries or solar panels
Started by hartiberlin, July 26, 2007, 09:40:54 PM
hartiberlin
Here is the latest video of Joe Newman pumping now more water.
Have not watched it fully yet, so no comment yet from me:
http://video.google.com/videoplay?docid=1755299866270167042
hartiberlin
Now it seems he pumps this much water with around only 20 Watts only.
Not bad.
This could easily be powered by a low output solar panel...
seekingknowledge
Hi all, nothing new on the joe newman website not only have we not seen a selflooping motor there dosnt seem to be any other demonstrations things seem to be quiet with him, at the end of the latest demonstration he asked for money which is very odd, the thing is im starting to get the feeling that he has retired and we arnt gunna see him again and that the plee for donations is a way of wraping things up with
whatever last bits of money he can get, i seriously hope that im wrong.
seekingknowledge
DECEMBER 2007
SPEED IS POWER
Speed is very important in a collision.
If you double the speed of a car,
you increase its force of impact four times.
If you triple the speed, the impact is nine times as great.
Accordingly, the Newman Energy Machine in principle
produces unlimited speed: unlimited power!
Above is the latest addition to the newman website just that no more no less which means no links, wow speed is power we understand what your on about joe lets see some action.
kmarinas86
Quote from: seekingknowledge on December 22, 2007, 06:04:21 PM
DECEMBER 2007
SPEED IS POWER
Well ok.  Let's see.
If you keep the resistance held, then power is proportional to current squared.  This is when you keep the same coil, not the same voltage.  If you want to get the most power out of 9V battery, then you use commutators to make the voltage of the wire go up and down as often as possible, because when ever the connection is not there, you are not using the voltage.  So basically, if you want to build more for you money, its best to at least double the number of commutator hits per rotation, and if doing so doubles the current, it will will quadruple the power, while only halving the longevity of the battery, so overall you get twice the energy output.  If instead of increasing the number of commutator touches you connect two 9V in series, keep in mind that the 9V batteries have a resistance of their own, so you won't be able to double the current that way.  Copper wire has resistance measured in ohms per kilometer, whereas a 9V battery may have several ohms.  You would also be eating up the batteries faster that way, not good for longevity.  Believe it or not, if your motor touches the commutator for long, then you are loosing a lot of charge.  There should only be enough to give it the kick.  Therefore I feel that trying to get most out the single battery is a good goal.  After all, a 9V battery costs $4.  And $4 can get you 100 kilowatt hours of electricity, or 43 days worth of nutritional calories.  What we need is a Newman machine that can run on a 9V battery with about 100 watts of output for 43 days.
Actually I have a better idea.  Because we know that resistance of the batteries are much higher than even 1 km of copper wire, we should NOT connect the batteries in series, because that won't change the current.  Not only that, it will waste the rest of the charges!  Instead, we should simply hook the batteries in parallel and have all them run at the same time so that we DO get more current. In fact, I tried this and got better results than when I connected them in series, I now have my Newman machine actually jumping now!
http://www.youtube.com/watch?v=TmIqy-Zk030
