extra electric power / power amp.
Started by ckm, April 03, 2005, 01:35:44 PM
rlm555339
Quote from: ckm on April 15, 2005, 12:45:26 PM
So you must already know that I can't test it, I don't have the stuff to build it with.
Building it is the only way to know for sure.
If this was to be run off the mains, then it may well require an (think it's still called an inverter) so the AC is converted to DC
a diode rectifies AC to DC; an inverter pulses DC and inverts it to make a modified sine wave, or AC
From what I recall about electrics, AC relies on high current to transport it over the long distances from the power stations to the sub-stations to the residential areas and corporate areas and industrial areas and so forth.
Most major transmission lines use HVDC to move huge amounts.  (lesser losses)  Higer voltages result in lower currents.  (high load currents are a bad thing (i.e. heat losses, etc)
Bottom line, the only way to understand your theory is to build it and test it.
Ronald Classen, 30+ years electrical tech
FreeEnergy
The SP 2000 Package sounds nice!  :)
lanca
the work of adolf zielinski and siegfried stargard could probably explain some potentials about current acceleration.
but this is more/les thermonuclear section technology-not easy to realize it to pocket size.
Ich habe heute den bestellten Autotransformer erhalten,
mit folgenden ,noch nicht selbst ueberprueften,Relationen:
In-put 12W und Out-put 550W,
In-put 36W und Out-put 770W.
Das System generiert diese Leistungen zu 100% elektro-magnetisch,
kein Permanent-Magnet mehr vorhanden !
Ich werde in den naechsten Tagen,nach erfolgter Pruefung,ueber die
Gueltigkeit der Daten berichten.
Ueber das System selbst,aufgrund Patentanmeldung,nicht !
MfG
     Lanca
p.s.:Grundziel ist die elektrische Infrastruktur einer autonomen Wohneinheit,
      wie  www.spacebox.info
      wobei der Gesamtpreis der e-module bei 750 Euro liegen sollte (4+1,3 KW)
      inklusive IR-Heizer.
      Die Kosten der autonomen Wohneinheit,bei 20qm, auf 6000 Euros taxiert !
      "ELEMENTALS"-Architektur-Wettbewerb(Chile) Preisniveau !
Kator01
Hallo LancaIV,
Sie plazieren diese Nachricht in deutsch ohne vorherige "threads". Was haben Sie denn da f?r ein Schn?ppchen gemacht. So einen Autotransformer gibt es zu kaufen ? Was ist denn der Preis ?
Ich bin sehr gespannt.
Hoffentlich sind die Outputleistungen, die da genannt werden, nicht Leuchtstoffr?hren-Leuchtleistungen, die wir ja schon vom MEG etc. her kennen.
Sie kennen ja meine Ausf?hrungen zu MEG und im besonderen zu Bushwacker HOPE.
Viel Gl?ck beim Testen
Kator01
