TPU Compiling
Started by stallman, August 16, 2007, 07:59:31 PM
stallman
This post is a general survey of what free energy machines do in general and the basic principle of physics they expose. I have included questions for Nikola Tesla?s wok, Henry Moray?s ?Sea of Energy,? E.V. Gray?s conversion tube circuit and finally extensive questions about the TPU.
In the following questionnaire I will be writing questions about each inventor?s work. I am going to ask a lot of question so as to not get confused could people please put the number of the question before your answer. If you have an additional fact to through in write ?fact-? in front of you fact, if it is a comment write ?comment-? before you comment.
After I get most of the people answers I will compile my finding and write a critique on what is really going on. I hope this will help most of the advanced TPU builder by suggesting other possible ways the TPU works and how it gets OU.
QUESTIONNARE
It all started with Tesla
1.   What was Tesla?s charge caring substance that he stated was smaller than the electron? Was it really just an electron or a subatomic particle (neutrinos, ect.)  or something to do with the vacuum (Aether, virtual photon, ect.)?
2.   What was the difference between a regular Tesla coil and Tesla?s Magnifying Transmitter?
3.   What are cosmic rays? Is it ions, electromagnetic radiation, subatomic particle, or the vacuum (Aether)?
4.   What is Aether (also spelled either) exactly.
5.   What is a Hertz waves (is these electromagnetic waves like light)? What are longitudinal waves and how do they differ from Hertz waves.
6.   What was the light emitted from Tesla experiments. It was different than conventional lights and did it come from the machine itself (I am guessing)?
Moray learned from Tesla
7.   Moray stated that energy from an external source is what created decay in all matter (the heavier elements showed most decay because of bigger atom size). He stated that he could keep some of this energy from flowing into radium which made his radium sample emit many time lower emissions. What was this energy?
8.   Has any one read an article about rocks that emitted light similar to the light created by Tesla?s experiments. One man found a stone that had this weird property and the light from it was so penetrating that it shown through his house making his neighbors frightened that his house was curse. The rock also made a banging sound every now and then. It seemed similar to the Sweet VTA. The rock was probably created when a quartz type rock with ferrite ore in it was struck by lightning (just guessing). Any one have any thought or explanations.
Edwin Gray and the modified Tesla coil
9.   Has anyone made a conversion tube (besides Bedini) and has it worked?
10.   Could some one take a Tesla coil and remove the primary and secondary coil then insert a conversation tube to see if there is any over unity gain?
11.   Has anyone experimented with the Tesla Switch?
12.   Did Tesla?s car use a conversion tube?
Finally the TPU
13.   What makes the TPU your favorite OU machine?
14.   What types of TPU designs are there (i.e. mobus rings, three ring four control, ect.)?
15.   Where is the TPU getting its additional energy from? Is it from back EMF, radiant events, MEG type magnet gating, Earth?s magnetic field, atmosphere Ions?
16.   What are seed and what are kicks?
17.   What is the simplest design to achieve OU (like turbo?s one control coil ring)?
18.   Has anyone touched the coil when it was functioning in OU? Could you feel anything? If you did what did it feel like?
19.   When was the last time Steve Mark talked to anyone about his invention and was his letter any help?
20.   Is the TPU like a big spinning toroidal magnet? If so, how does the TPU capture this energy and is any energy from the environment into to TPU?
This is my first questionnaire. This will be an experiment to see how much answers I get (I am hoping for a lot). If you have a question to contribute write ?question-? in front of your question and I will incorporate it into next questionnaire. I hope that with all these answers we can merge all the information about nature these ?freak experiments?, as would be called by regular scientists, to better understand at what the TPU is doing.
Stallman
Gothic
Q13.  Ans= Because with the info provided you theoretically could goto to your local
                 junkyard and build one, for nothing.  that,s if this thing isn,t some
                 elaborate hoax,  like the war of the worlds broadcast, a psyops of sorts
                 to guage what the natives are thinking.
tao
FACT - John Bedini never got to the point where his Gray tube replication worked! He built the tube, but NEVER got it powered as Gray did...
tao wrote:
Dear John,
There are some questions that I always wanted to ask you, and if you would be so kind....
After you built and replicated Gray's tube, did you ever power light bulbs and stick them in water it to make sure you were actually producing Gray's 'cold' electricity?
I know that you said you were using it for 'healing,' considering this, I am sure you know about Robert Beck, if not ask Peter. Anyway, did you use this 'tube' for anything other than 'healing'?
And lastly, and perhaps MOST importantly, Do you see Gray's tube functioning in the same manor as your monopole inductors? Meaning, that you input 'normal' electricity into it in order to CAPTURE your 'radiant' output? And do you consider Gray's 'cold' electricity to merely be what you call your 'radiant energy'?
One quote from you I'll always remember is:
"I must keep this simple
Let's look at it this way, If we go back to where Tesla said that when the switch was thrown in the DC power station the operator was killed by some unknown! Tesla studies this , He reproduces it in his lab where he says that a great stinging pain was felt by him ( the gaseous fluid, not controllable passes through everything). He finds out that just before the current carriers catch up and enters the highly resistive inductor (by sharp reparation rate) their is a radiant pulse that causes the wire to emit a glow that takes place, then the current catches up and it goes away (normal positive EM power). Then the current is cut off and a back EMF develops. These are two different things! In my tests I have found that the radiant only appears to tranverse the coil when voltage appears, in other words this radiant pulse is there when the voltage potential leads the switching, then the current makes it's way through the resistave coil. But now the switch is off and the back EMF shows up only reverse at 1/3 the radient pulse, so in a sence you could say this all takes place unidirectional in millisecond of time."
Thanks again for everything John...
John Bedini wrote:
Tao,
No I did not, I was chased away from this work. I wanted to build the power supply but things got nasty. And yes it is the same cold electricity, and yes it was radiant energy. and yes it is splitting the positives. I never forgot Gray's demo with the magnets, you could not believe how fast they took off.
Gray was something else. The motor did run and recharge the batteries. He could run this motor for hours, it was cold to the touch, made a popping sound. He did show us a drawing of the motor in a car, but then Tesla had the same thing.
Hope this helps you.
John
stallman
@toa
Wow I can't believe that Bedini just didn't make the simple circuit which was a Tesla coil circuit that could be powered by 12v batteries (Lindemann explained in one of his videos). It would of taken a neon sign transformer, capacitator and, a spark gap. He has the protection to show what ever he wants. He made a freaking movie in his factory. If he used them for healing he must of powered them up. If he was getting those so called 1000 amp sparks he would of incorporated this in to his monopole motors.
Is John Bedini reliable? I am assuming his monopole engine designs create over unity.
So I'm guessing that he basically tried the tube and didn't get any over unity or he did but wants to keep it secret (I'm guessing the first).
I was curious about the EV Gray circuit because it seemed easier to build than the TPU and also it could be scaled up easily to power a city. I guess that answers that the TPU is what I'm going to focus on from now on.
If you know of anyone else that reproduced the conversion tube please tell me.
tao
Quote from: stallman on August 17, 2007, 03:17:59 AM
@toa
No, it is neither. Bedini NEVER tried the tube. He never built the power supply as Gray had it. That is what I am saying, everyone looks at Bedini's tube and thinks that he has already made a perfect replica of Gray's tube, yet he has never powered it, by his own admission.
One man who claims to HAVE replicated Gray's tube and circuitry is G. Magratten, he has a site at www.coldelectricity.info
I have had email conversations with him and watched over his work, he claims to have replicated Gray's tube, but in a smaller fashion.
http://www.pureenergysystems.com/os/EdGrayMotor/PM_PEM_MG/plans/proto1GM/index.html
