Chas Campbell Flywheel Generator
Started by wattsup, September 09, 2007, 12:42:30 PM
Low-Q
Quote from: wattsup on September 09, 2007, 12:42:30 PM
Ok, I am starting this new thread to get away from the Chas Campbell Perpetual Motion Wheel cause there is just too much clutter and blah blah.
I put this in the RV section because there is no section on the board dealing with no-name brand non-RV motor generators, at least I could not find one.
I have also removed the prevous text below figuring those that needed to read it have done so. there is no point to leave it continuously.
I am putting the original design of Chas' Flywheel Generator (CFG) below and will add any pretinent build information here as it is identified.
I know that the original post is 11 years old - from 2007, but I modifyed the initial design with a simpler version, that also doesn't work as intended - LOL ;D
If you translate all the gear ratios (well belts), you end up with this design. Will it work? No, but better than the original one.
Vidar
Low-Q
If the flywheel is the secret, you don't need the motor.
Since a flywheel isn't over unity, then you don't need that one.
If the generator has nothing to run it, you don't need the generator.
So you end up with this design...
Vidar
rakarskiy
Not everything is prosaic: the "effect" is that the kinetic energy of the rotating mass of matter has a quadratic dependence on the velocity and, consequently, on the radius. An increase in the rotation speed by a factor of 3 leads to an increase in the kinetic energy due to the factor 9 "
you need to know exactly what to connect with. You think too much of energy, but the flywheel is Kinetic Energy. In addition, he has many other properties about which you just do not guess, but they are all known about and described in textbooks.
rakarskiy
Quote from: Low-Q on August 21, 2018, 02:07:07 PM
Vidar
Look at this video it will be interesting to you.
https://www.youtube.com/watch?v=DBgFq-19TDk
wheatbelt
hmm it does seem silly, but let me know if it works !!. because it would just be evidence of an engineer accidently cocking up and making a cop+1 motor or gen
in my experience and youtube videos ;-). i find it best too weld together, 2 independant working free energy machines, and include my deepest sarcasm.. but it does work.
