The IST simple Cap charger / RE convertor
Started by innovation_station, September 28, 2007, 09:19:51 AM
innovation_station
a wile ago i built a coil that can do this and it is not a tpu
i put 5v dc in at the right freq and on the kick back 1000v  blew my fuse in my meter it was 750vac @.8amp
but there majour problems with it rf noise = a bad thing
it was powered by pluses when the correct freqency was found it would interact with my computer speekers making them click and stuff at that time  i could mesure big peeks of power on my meter
altho i did post this in the LOTR thred some time ago i deleted it but reposted some of it i will find the link and post it here  i might just fire this coil up agin and make a video of it  this was1 of my first 5 coils i built
ist
innovation_station
when i first built this coil i could not take any power from it i tryed to light a bulb but had no luck so .....  i left it there after a while  but later on in my work on the tpu i discovered how to harness that power  ;) and it was verry easy i have  not since played with that coil but i know i can collect this power now so i think i will throw somthing togather out of it that will give back more than used to operate
it should be verry easy to do
ist
innovation_station
acerzw
@Is
That coil looks good, I am glad you have re-posted, please update as soon as possible with complete details. If this coil can be reproduced getting the voltage out as you say should not be a problem, it might be possible to self-run and make a TPU like device or better.
If you still have the coil can you examine it and give the specs: dimensions, windings, wire type, windings and length, so other can try...
Acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
innovation_station
in this next link you see how i collect the re  now put the above coil with this setup - the magnets replace the spark gap with a switch a fet or a relay or a tube or what ever you want so now i should be able to collect the 1000v kickback or keep the freq off a wee bit more so the kickback is not as much when i did the original coil test it was plused by hand
http://www.overunity.com/index.php/topic,1872.2130.html
ist
